Installing Gazebo 9 and 10 from source
Hi guys,
I tried to install gazebo 9 and 10 from source on Ubuntu 16.04: link text.
I got these errors:
-- BUILD ERRORS: These must be resolved before compiling.
--  Missing: SDF version >=6. Required for reading and writing SDF files.
--  Missing: Ignition msgs1 library (libignition-msgs-dev).
--  Missing: Ignition math (libignition-math4-dev)
--  Missing: Ignition Transport (libignition-transport4-dev)
-- END BUILD ERRORS
After installing the package libsdformat6-dev i got these errors :
-- END BUILD ERRORS
Even if I install the libignition-msgs-dev and libignition-transport4-dev. I still get exactly the same error message:
-- END BUILD ERRORS
I had to come back to gazebo 8 because it's the only version which work with the gui plugins. See this page for more information: link text Fyi, I tried a fresh install gazebo 9 and 10 on a computer that never had any gazebo installed on it.
Do you have an idea how to fix this issue?
Asked by jordan on 2018-12-13 08:17:28 UTC
Did you do the apt-get remove... step before installing?
Asked by chapulina on 2018-12-14 17:07:02 UTC
As explained in the post, yes I followed the information on that link: http://gazebosim.org/tutorials?tut=install_from_source and I've tried to install gazebo 9 and 10 on a computer that never had any gazebo installed on it.
Asked by jordan on 2019-01-07 03:24:10 UTC
@jordan did you find a solution to your issue?
Asked by xype_totec on 2020-05-23 08:09:01 UTC
