Gimbal not working in X4 robot
I tried to add gimbal mechanism in X4 robot by modifying some x4 robot xacro but i'm always getting msg" Controller Spawner couldn't find the expected controller_manager ROS interface."
In x4withsensors.xacro file i added transmission element and gazeboroscontrol plugin as:
<xacro:if value="$(optenv X4_SENSOR_CONFIG_4 0)">
<xacro:camera_macro
namespace="${namespace}"
parent_link="${namespace}/base_link"
camera_suffix="front"
frame_rate="20"
horizontal_fov="2"
image_width="1280"
image_height="960"
image_format="R8G8B8"
min_distance="0.02"
max_distance="100"
noise_mean="0.0"
noise_stddev="0.007"
enable_visual="true">
<box size="0.02 0.05 0.05" />
<origin xyz="0.1 0 0" rpy="0 0 0" />
</xacro:camera_macro>
<planar_lidar
name="${namespace}/laser"
topic="${namespace}/scan"
mesh="package://subt_sensors/meshes/sick-lms1xx.dae"
min_angle="-2.3562"
max_angle="2.3562"
min_range="0.5"
max_range="20"
update_rate="20"
<joint name="front_laser_mount_joint" type="continuous">
<origin xyz="0 0 -0.05" rpy="0 0 0" />
<parent link="${namespace}/base_link" />
<child link="${namespace}/laser" />
<dynamics damping="0.7"/>
</xacro:if>
<transmission name="tran1">
<joint name="front_laser_mount_joint">
<hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
<actuator name="motor1">
</actuator>
</transmission>
<gazebo>
than i loaded configuration for this joint from a file like: x4withsensors:
# Publish all joint states -----------------------------------
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
# Position Controllers ---------------------------------------
joint1_position_controller:
type: effort_controllers/JointPositionController
joint: front_laser_mount_joint
pid: {p: 100.0, i: 0.01, d: 10.0}
than i loaded it from a launch file with lines:
<rosparam file="$(find subt_seed)/config/gimbal.yaml" command="load"/>
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
output="screen" args="joint_state_controller
joint1_position_controller"/>
Asked by hari1234 on 2019-01-04 04:37:28 UTC
