Color not shown in Gazebo using dae files
I have an issue with Gazebo and color. I am using Blender to attach materials with different colors to different faces of a mesh.
When I export the model as a collada file (.dae) and load it into Gazebo the model has no colors. In rviz all colors show correctly. See screenshot:
I have noticed that the ambiet values in the dae file look like this:
<ambient>
<color sid="ambient">0 0 0 1</color>
</ambient>
In gazebo the values were set to 1, so I changed all ambient values to
<ambient>
<color sid="ambient">1 1 1 1</color>
</ambient>
Unfortunately the outcome was the same. I have also added some light sources which didnt help.
My export settings in Blender look like this
The collada file looks like this: C:\fakepath\colortest3.model
Gazebo version used: Gazebo multi-robot simulator, version 9.6.0
Blender version: Blender 2.79 (sub 0)
ROS version: melodic
OS: Ubuntu 18.04.1 LTS
What could I be doing wrong?
BR
Asked by Eisenhorn on 2019-01-14 05:02:09 UTC
Hey did you solve this problem? Because I have the same. When I color the blender elements, they are still standard in gazebo - gray. Previously, I created these elements in solidworks and then imported them into the blender as stl format, then colored them in the blender and exported them as dae format.
Asked by Wishram on 2020-12-17 09:58:41 UTC
Exactly the same problem here. Did you find any solution?
Asked by rasecg3 on 2019-05-10 08:30:49 UTC
I have a similar problem. The object is not even shown at all, when I add a tag in the sdf than it is shown in this color. Did you find any solution yet?
Asked by edward on 2019-08-22 07:47:27 UTC
I have tried it recently again with Belnder 2.79 b. Gazebo is now on 9.11.0. I have used the same export properties and in the material surface settings I choose Diffuse -> chosse color -> intensity was set to 0.8 -> Shader Model Lambert. It seems to work now. Interstingly ambient is 0 0 0 1 ... Could you try with the mentioned versions?
Asked by Eisenhorn on 2019-09-30 03:37:06 UTC
