Robot simulation wheels spinning on the spot malfunction
My URDF is loading in Gazebo and I issue a twist command to move the robot along the x-axis.
The problem is the wheels malfunction by spinning instead of rotating and moving the robot as shown in the image below:
I would appreciate some help with this.
My urdf code is below:
<?xml version="1.0"?>
<robot name="mybot">
<gazebo>
<plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so">
<legacyMode>false</legacyMode>
<alwaysOn>true</alwaysOn>
<publishWheelTF>true</publishWheelTF>
<publishTf>1</publishTf>
<publishWheelJointState>true</publishWheelJointState>
<updateRate>100.0</updateRate>
<leftJoint>left_wheel_joint</leftJoint>
<rightJoint>right_wheel_joint</rightJoint>
<wheelSeparation>1.1</wheelSeparation>
<wheelDiameter>0.52</wheelDiameter>
<wheelAcceleration>1.0</wheelAcceleration>
<torque>20</torque>
<material name="blue">
<color rgba="0 0 0.8 1"/>
<material name="black">
<color rgba="0 0 0 1"/>
<material name="white">
<color rgba="1 1 1 1"/>
<material name="red">
<color rgba="1 0 0 1"/>
<link name="base_link">
<visual>
<cylinder length="0.015" radius="0.2"/>
<material name="white"/>
<collision>
<origin xyz="0 0 1" rpy="0 0 0"/>
<mass value="1"/>
<inertia
ixx="1.0" ixy="0.0" ixz="0.0"
iyy="1.0" iyz="0.0"
izz="1.0"/>
<link name="upper_level">
<visual>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name='upper_level_joint' type='fixed'>
<parent link='base_link'/>
<child link='upper_level'/>
<origin rpy='0 0 0' xyz='0 0 0.05'/>
<link name='seperator_1'>
<visual>
<origin rpy='0 0 0' xyz='-0.120 0.085 -0.02'/>
<material name='white'/>
<cylinder length='0.07' radius='0.003'/>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name='upper_level_sperator_1_joint' type='fixed'>
<parent link='upper_level'/>
<child link='seperator_1'/>
<origin xyz='0 0 0'/>
<link name='seperator_2'>
<visual>
<origin rpy='0 0 0' xyz='-0.120 -0.085 -0.02'/>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name='upper_level_sperator_2_joint' type='fixed'>
<child link='seperator_2'/>
<link name='seperator_3'>
<visual>
<origin rpy='0 0 0' xyz='0.120 -0.085 -0.02'/>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name='upper_level_sperator_3_joint' type='fixed'>
<child link='seperator_3'/>
<link name='seperator_4'>
<visual>
<origin rpy='0 0 0' xyz='0.120 0.085 -0.02'/>
<collision>
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name='upper_level_sperator_4_joint' type='fixed'>
<child link='seperator_4'/>
<link name="left_wheel">
<visual>
<origin rpy="1.57075 0 1.5" xyz="0 0 0.085"/>
<cylinder length="0.03" radius="0.035"/>
<material name="black"/>
<collision>
<!-- <surface> -->
<gazebo reference="left_wheel">
<mu1>100.0</mu1>
<mu2>50.0</mu2>
<kp>1000000.0</kp>
<kd>100.0</kd>
<minDepth>0.001</minDepth>
<maxVel>1.0</maxVel>
<!-- </surface> -->
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name="left_wheel_joint" type="continuous">
<parent link="base_link"/>
<child link="left_wheel"/>
<origin rpy="0 0 0" xyz="0.133333333333 0 -0.085"/>
<axis xyz="0 0 1"/>
<link name="right_wheel">
<visual>
<collision>
<!-- <surface> -->
<gazebo reference="right_wheel">
<mu1>100.0</mu1>
<mu2>50.0</mu2>
<kp>1000000.0</kp>
<kd>100.0</kd>
<!-- </surface> -->
<mass value="1"/>
<inertia
iyy="1.0" iyz="0.0"
izz="1.0"/>
<joint name="right_wheel_joint" type="continuous">
<child link="right_wheel"/>
<origin rpy="0 0 0" xyz="-0.133333333333 0 -0.085"/>
<axis xyz="0 0 1"/>
</robot>
Asked by sisko on 2019-01-21 20:43:47 UTC
