Gazebo outputs the same value two times
I apply some torques to the joint of a robot arm and output the current time, angle, velocity and torque value to terminal everytime when the simulation is updated.
Every two lines are the same. Why? Can I let it just display once?
Below are my terminal and code snippet.
namespace gazebo
class ModelPush : public ModelPlugin
private: int count = 0;
private: float tor[10] = {1,2,3,4,5,6,7,8,9,10};
private: physics::JointPtr joint;
public: void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
this->model = _parent;
this->joint = this->model->GetJoint("arm_shoulder_pan_joint");
std::bind(&ModelPush::OnUpdate, this));
public: void OnUpdate()
this->joint->SetForce(0, tor[count++%10]);
cout << fixed << this->model->GetWorld()->GetSimTime() << "\t";
cout << fixed << "pos=" << this->joint->GetAngle(0).Radian() << "\t";
cout << fixed << "vel=" << this->joint->GetVelocity(0) << "\t";
cout << fixed << tor[count%10] << endl;
GZ_REGISTER_MODEL_PLUGIN(ModelPush) }
Asked by jwchang on 2019-01-24 23:05:24 UTC
This may seem like an obvious question, but do you have only one plugin loaded? Maybe also print the model name and the plugin address (this)?
Asked by chapulina on 2019-01-25 12:05:10 UTC
