IMU sensor update rate is overwritten by GPS sensor
When adding a GPS sensor to my model, the update rate it uses overwrites the update rate of my IMU. I wish to have for example then GPS sensor running at 5 Hz and the IMU at 100 Hz.
Here is a basic model which shows this behaviour for me:
<?xml version="1.0"?>
<robot name="GPSIMU" xmlns:xacro="http://ros.org/wiki/xacro">
<link name="base">
<mass value="0.7" />
<inertia ixx="0.1" ixy="0.0" ixz="0.0" iyy="0.1" iyz="0.0" izz="0.1" />
<visual>
<geometry> <box size="1 1 1" /> </geometry>
<collision>
<gazebo reference="base">
<sensor type="gps" name="gps">
<update_rate>5</update_rate>
<sensor type="imu" name="imu">
<update_rate>100</update_rate>
</robot>
gz topic -z /gazebo/default/GPSIMU/base/imu/imu gives me ~ 5 Hz, instead of 100 Hz.
I am using Gazebo 9.6.0 installed from the repos on Ubuntu 16.04
Asked by dom on 2019-02-11 21:05:36 UTC
