Banana rotates by itself in Gazebo, I don't know why
I'm using gazebo7 in ubuntu16.04.
I launch a bannana model in gazebo,everything is ok but the bannana will rotate slowly by itself.
urdf below:
<?xml version="1.0" ?>
<robot name="Bannana">
  <material name="yellow">
        <color rgba="1 0.4 0 1"/>
  <link name="Bannana">
      <origin
        xyz="0.0014177 4.15280000000162E-06 0.026526"
        rpy="0.0 0.0 0.0" />
      <mass
        value="0.11082" />
      <inertia
        ixx="2.48347659000621E-05"
        ixy="1.68484882757417E-06"
        ixz="-1.05360215654521E-06"
        iyy="0.000186690109925898"
        iyz="1.13501975389491E-08"
        izz="0.000175609996584435" />
    <visual>
      <origin xyz="0 0 0" rpy="1.5707963267949 0 0" />
        <mesh
          filename="package://object_description/meshes/Bannana.STL" />
      <material name="yellow" />
    <collision>
        <mesh
  <gazebo reference="Bannana">
            <material>Gazebo/Yellow</material>
</robot>
launch file below:
<launch>
  <!-- these are the arguments you can pass this launch file, for example paused:=true -->
  <arg name="use_sim_time" default="true"/>
  <arg name="headless" default="false"/>
  <arg name="debug" default="false"/>
  <arg name="world_name" default="$(find object_gazebo)/world/table.world"/>
  <!-- We resume the logic in empty_world.launch -->
    <arg name="debug" value="$(arg debug)" />
    <arg name="gui" value="$(arg gui)" />
    <arg name="paused" value="$(arg paused)"/>
    <arg name="use_sim_time" value="$(arg use_sim_time)"/>
    <arg name="headless" value="$(arg headless)"/>
    <arg name="world_name" value="$(arg world_name)" />
  <!-- Load the URDF into the ROS Parameter Server -->
  <param name="robot_description" command="$(find xacro)/xacro --inorder '$(find object_description)/urdf/Bannana.urdf'" />
  <!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot -->
  <node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
    args="-urdf
        -model Bannana
        -param robot_description
        -x 0
        -y 0
        -z 1 "/>
</launch>
Here is the workspace link,and there is a bannana.gif in the home directory to describe the question.
Can you give me some advice? Thanks a lot!
Asked by TouchDeeper on 2019-02-13 23:29:44 UTC
It looks like the contacts between the banana and the table may be unstable. You can inspect them by choosing View -> Transparent and View -> Contacts.
One solution would be to tweak the surface parameters of the banana's collision. Something like this:
    <surface>
      <friction>
        <ode>
          <mu>0.5</mu>
        </ode>
      </friction>
      <contact>
        <ode>
          <min_depth>0.001</min_depth>
          <kp>1e9</kp>
        </ode>
      </contact>
    </surface>
Asked by chapulina on 2019-02-19 11:18:42 UTC
I enlarge the mass by 10 times, and enlarge the inertial by 100 times, the rotate disappear. It is just a solution. I don't know the reason.
Asked by TouchDeeper on 2019-03-28 08:53:06 UTC
