Why is a robot's link sinking under ground when I assign to it z axis coordinate of 0 at each update
I have a model plugin, in which on each update, I set a z axis position of a floating link to zero.
math::Pose pose = this->link_ptr->GetRelativePose();
pose.pos.z=0.0;
this->link_ptr->SetRelativePose(pose);
When I run the simulation, the link slowly sinks under the ground and continues slowly falling down. What is happening? How can I fix it?
EDIT
I found out, that the link is not sinking if I turn the gravity off for the individual link. What is happening? That is definitively not how this ought to work. Is it a bug?
Moreover I can't set the gravity to false from the URDF description, as it gets reset after the conversion to SDF (viz this issue). Anybody faced this issue before?
EDIT 2
the source file of the model plugin:
#include <ros/callback_queue.h>
#include "CoverPlugin.hh"
namespace gazebo
    // Constructor
    CoverPlugin::CoverPlugin()
    // Default plugin init call.
    void CoverPlugin::Init()
    void CoverPlugin::Load( physics::ModelPtr _parent,
                                sdf::ElementPtr _sdf)
        // Get the world name.
        this->world = _parent->GetWorld();
        this->model = _parent;
        // Get link
        std::string link_ptr_name = this->model->GetName() + "::"
            + "cover_link";
        this->link_ptr = this->model->GetLink(link_ptr_name);
            boost::bind(&CoverPlugin::OnUpdate, this));
        ros::AsyncSpinner spinner(2); // Use 2 threads
        spinner.start(); // spin() will not return until the node has been shutdown
    void CoverPlugin::OnUpdate()
        if( this->link_ptr->GetRelativePose().pos.z < 0.0 )
            pose.pos.z=0.0;
        if( this->link_ptr->GetRelativePose().pos.x > 0.028 )
            pose.pos.x=0.028;
        if( this->link_ptr->GetRelativePose().pos.y > 0.014 )
            pose.pos.y=0.014;
        if( this->link_ptr->GetRelativePose().pos.z > 0.01 )
            pose.pos.z=0.01;
        if( this->link_ptr->GetRelativePose().pos.x < -0.028 )
            pose.pos.x=-0.028;
        if( this->link_ptr->GetRelativePose().pos.y < -0.014 )
            pose.pos.y=-0.014;
        if( this->link_ptr->GetRelativePose().rot.x > 0.05 )
            pose.rot.x=0.05;
        if( this->link_ptr->GetRelativePose().rot.y > 0.05 )
            pose.rot.y=0.05;
        if( this->link_ptr->GetRelativePose().rot.z > 0.05 )
            pose.rot.z=0.05;
        if( this->link_ptr->GetRelativePose().rot.x < -0.05)
            pose.rot.x=-0.05;
        if( this->link_ptr->GetRelativePose().rot.y < -0.05 )
            pose.rot.y=-0.05;
        if( this->link_ptr->GetRelativePose().rot.z < -0.05 )
            pose.rot.z=-0.05;
        math::Vector3 force;
        math::Vector3 torque;
        force.x = -pose.pos.x*10000;
        force.y = -pose.pos.y*10000;
        force.z = -pose.pos.z*50000;
        torque.x = -pose.rot.x*100;
        torque.y = -pose.rot.y*100;
        torque.z = -pose.rot.z*100;
        this->link_ptr->SetForce(force);
header file:
#ifndef COVER_PLUGIN_HH
#define COVER_PLUGIN_HH
#include <gazebo/gazebo.hh>
#include "ros/ros.h"
#include "std_msgs/Bool.h"
#include <gazebo/math/Pose.hh>
#include <gazebo/math/Vector3.hh>
namespace gazebo
    class CoverPlugin : public ModelPlugin
        // Constructor.
        public: CoverPlugin();
        public: void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf);
        private: physics::WorldPtr world;
        private: physics::LinkPtr link_ptr;
        public: virtual void Init();
        private: void OnUpdate();
        private: std::unique_ptr<ros::NodeHandle> rosNode;
    GZ_REGISTER_MODEL_PLUGIN(CoverPlugin)
#endif
Asked by kumpakri on 2019-02-20 05:36:45 UTC
What is the parent link of the link? The documentation says: Set the pose of the entity relative to its parent. So this could may be the cause of the problem.
Asked by wentz on 2019-02-21 02:36:03 UTC
The parent link is the chassis of the robot, which stays standing above the ground the whole time. The floating link moves with respect to it's parent in z axis.
Asked by kumpakri on 2019-02-21 03:26:49 UTC
Not easy. Can you post the source code of your model plugin?
Asked by wentz on 2019-02-21 04:30:02 UTC
source code added to the question.
Asked by kumpakri on 2019-02-22 08:36:51 UTC
Did you solve this issue?
Asked by aravindsrj on 2020-08-31 14:33:54 UTC
