how to choose an SDFormat spec version
Are there any resources out there on how to choose an SDF spec version?
As I have been playing around with SDF elements in my .xacro files, I learned that there are several versions of the SDF spec. I'm currently using Gazebo9 and SDF6. From looking at the code it appears that SDF6 defaults to the SDF 1.4 spec. Why not 1.5 or 1.6?
For my particular project I am interested in the initialposition element for my joints. initialposition is only available in SDF 1.6 and I haven't been able to get it to work. From looking at the code a little I don't think it has even been implemented. Can anyone comment on that?
Asked by mogumbo on 2019-02-26 19:40:39 UTC
Also this: According to http://gazebosim.org/tutorials?tut=model_structure the SDF version is not required for URDFs. So if you use gazebo_ros spawn_model to load a URDF, what version of the SDF spec is used to load it?
Asked by mogumbo on 2019-02-27 13:30:07 UTC
