Tutorial Intermediate: Velodyne, not spinning. Just Gazebo, no ros
Should there be any indication of spin?
- Should the Force tab values reset to 0.0 anytime you click away?
- Is there starting and ending code for these tutorials? I could solve my issue with that...
Unrelated, but really I must know.. are there plans to implement an undo button or load function to compliment the saveas function? I see that someone asked about the undo button a couple of years ago and was told it was implemented for gazebo8, but I am running gazebo9 so maybe that isn't available anymore?
From: http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i1
<?xml version="1.0" ?>
<sdf version="1.5">
<world name="default">
<uri>model://sun</uri>
<!-- A ground plane -->
<model name="velodyne_hdl-32">
<!-- Give the base link a unique name -->
<link name="base">
<!-- Offset the base by half the lenght of the cylinder -->
<pose>0 0 0.029335 0 0 0</pose>
<mass>1.2</mass>
<ixx>0.001087473</ixx>
<iyy>0.001087473</iyy>
<izz>0.001092437</izz>
<collision name="base_collision">
<cylinder>
<!-- Radius and length provided by Velodyne -->
<radius>.04267</radius>
<length>.05867</length>
</cylinder>
<!-- The visual is mostly a copy of the collision -->
<visual name="base_visual">
<cylinder>
</cylinder>
<link name="top">
<!-- Vertically offset the top cylinder by the length of the bottom
cylinder and half the length of this cylinder. -->
<pose>0 0 0.095455 0 0 0</pose>
<mass>0.1</mass>
<ixx>0.000090623</ixx>
<iyy>0.000090623</iyy>
<izz>0.000091036</izz>
<collision name="top_collision">
<cylinder>
<radius>0.04267</radius>
<length>0.07357</length>
</cylinder>
<visual name="top_visual">
<cylinder>
</cylinder>
<!-- Each joint must have a unique name -->
<joint type="revolute" name="joint">
<!-- Position the joint at the bottom of the top link -->
<pose>0 0 -0.036785 0 0 0</pose>
<!-- Use the base link as the parent of the joint -->
<parent>base</parent>
<!-- Use the top link as the child of the joint -->
<child>top</child>
<!-- The axis defines the joint's degree of freedom -->
<axis>
<!-- Revolve around the z-axis -->
<xyz>0 0 1</xyz>
<!-- Limit refers to the range of motion of the joint -->
<limit>
<!-- Use a very large number to indicate a continuous revolution -->
<lower>-10000000000000000</lower>
<upper>10000000000000000</upper>
</limit>
</axis>
</world>
Version. Newest, installed with ROS, Ubuntu 18.04 lts:
$ gazebo --version
Gazebo multi-robot simulator, version 9.0.0
Asked by zebago on 2019-03-15 22:35:59 UTC
