Husky wheels don't turn below a threshold
I'm trying to test a custom local planner on a Husky on Gazebo. The Husky responds well to angular and linear velocities commanded by tele-operation. However, the Husky doesn't respond when the angular velocity commanded by move_base
is below 0.25 m/sec. It does respond to the linear velocity commanded by move_base
I tried changing the friction parameters and fdir parameters but to no avail. Please find below an excerpt of the URDF file pertaining to the wheel simulation parameters:
<gazebo reference="${wheel_prefix}_wheel_link">
<mu1 value="0.3"/>
<mu2 value="0.3"/>
<kp value="10000000.0" />
<kd value="0.75" /> <!-- was 1 -->
<fdir1 value="1 0 0"/>
<joint name="${wheel_prefix}_wheel" type="continuous">
<parent link="base_link"/>
<child link="${wheel_prefix}_wheel_link"/>
<xacro:insert_block name="joint_pose"/>
<axis xyz="0 1 0" rpy="0 0 0" />
<transmission name="${wheel_prefix}_wheel_trans" type="SimpleTransmission">
<actuator name="${wheel_prefix}_wheel_motor">
</actuator>
<joint name="${wheel_prefix}_wheel">
</transmission>
How do I get the wheels to respond at all angular velocities? Thank you in advance!
Asked by curi_ROS on 2019-03-28 02:43:45 UTC
