Connect to gazebo using a custom socket client
My goal here is to control a model in gazebo using keys from the keyboard. I was able to do that using plugins within gazebo using a publisher and subscriber pattern that sends and receives information over topics. But now I want to achieve the same by a completely independent process say using ZeroMQ that does not include any gazebo dependencies. Can you guys give me any insights to this. It will be very helpful.
Code for plugin1:
KeyboardGUIPlugin::KeyboardGUIPlugin()
: GUIPlugin(), dataPtr(new KeyboardGUIPluginPrivate)
gazebo::gui::MainWindow *mainWindow = gazebo::gui::get_main_window();
if (!mainWindow)
gzerr << "Couldn't get main window, keyboard events won't be filtered."
<< std::endl;
return;
mainWindow->installEventFilter(this);
// Make this invisible
this->move(-1, -1);
this->resize(1, 1);
// Initialize transport.
// Publish the key presses to the autoCrane topic
this->dataPtr->gzNode = transport::NodePtr(new transport::Node());
this->dataPtr->gzNode->Init();
this->dataPtr->keyboardPub =
this->dataPtr->gzNode->Advertise<msgs::Any>("~/keyboard/keypress");
KeyboardGUIPlugin::~KeyboardGUIPlugin()
this->dataPtr->keyboardPub.reset();
this->dataPtr->gzNode->Fini();
// Send the message
void KeyboardGUIPlugin::OnKeyPress(const gazebo::common::KeyEvent &_event)
msgs::Any msg;
msg.set_type(msgs::Any_ValueType_INT32);
msg.set_int_value(_event.key);
this->dataPtr->keyboardPub->Publish(msg);
bool KeyboardGUIPlugin::eventFilter(QObject *_obj, QEvent *_event)
// Check if there was a keypress in a child
if (_event->type() == QEvent::ShortcutOverride)
QKeyEvent *qtKeyEvent = dynamic_cast<QKeyEvent *>(_event);
gazebo::common::KeyEvent gazeboKeyEvent;
gazeboKeyEvent.text = qtKeyEvent->text().toStdString();
// QKeyEvent::key() does not distiguish between lowercase and uppercase.
// Need to use QKeyEvent::text() to get the unicode character.
// Special keys (shift, ctrl) will have an empty text field.
gazeboKeyEvent.key = !gazeboKeyEvent.text.empty() ? gazeboKeyEvent.text[0] :
qtKeyEvent->key();
this->OnKeyPress(gazeboKeyEvent);
return QObject::eventFilter(_obj, _event);
code for plugin2:
void KeysToJointsPlugin::Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
this->model = _model;
auto controller = this->model->GetJointController();
// Load params from SDF
if (_sdf->HasElement("map"))
auto mapElem = _sdf->GetElement("map");
while (mapElem)
// Get the joints from the sdf file
auto jointName = mapElem->Get<std::string>("joint");
auto joint = this->model->GetJoint(jointName);
if (!joint)
// It will complain if no joints are found
gzwarn << "Can't find joint [" << jointName << "]" << std::endl;
else
// The joint should have the below characteristics
if (!mapElem->HasAttribute("key") ||
!mapElem->HasAttribute("scale") ||
!mapElem->HasAttribute("type"))
gzwarn << "Missing [key], [scale] or [type] attribute, skipping map."
<< std::endl;
mapElem = mapElem->GetNextElement("map");
continue;
KeyInfo info;
info.key = mapElem->Get<int>("key");
info.joint = joint;
info.scale = mapElem->Get<double>("scale");
info.type = mapElem->Get<std::string>("type");
if (info.type != "force")
double kp = 0;
double ki = 0;
double kd = 0;
if (mapElem->HasAttribute("kp"))
kp = mapElem->Get<double>("kp");
if (mapElem->HasAttribute("ki"))
ki = mapElem->Get<double>("ki");
if (mapElem->HasAttribute("kd"))
kd = mapElem->Get<double>("kd");
common::PID pid(kp, ki, kd);
if (info.type == "position")
controller->SetPositionPID(info.joint->GetScopedName(), pid);
else if (info.type == "velocity")
controller->SetVelocityPID(info.joint->GetScopedName(), pid);
this->keys.push_back(info);
this->node = transport::NodePtr(new transport::Node());
this->node->Init();
// subscribe to KeyboardGUIPlugin by registering OnKeyPress() callback
this->keyboardSub =
this->node->Subscribe("~/keyboard/keypress",
&KeysToJointsPlugin::OnKeyPress, this, true);
void KeysToJointsPlugin::OnKeyPress(ConstAnyPtr &_msg)
for (auto &key : this->keys)
if (_msg->int_value() != key.key)
continue;
if (key.type == "position")
auto currPos = key.joint->Position(0);
controller->SetPositionTarget(key.joint->GetScopedName(),
currPos + key.scale);
else if (key.type == "velocity")
controller->SetVelocityTarget(key.joint->GetScopedName(),
key.scale);
else if (key.type == "force")
key.joint->SetForce(0, key.scale);
Asked by kangkan on 2019-04-18 11:33:59 UTC
Hi, did you solve this issue? If so, could you provide your solution or at least roughly say, how you did it?
Asked by m.bahno on 2021-11-25 10:37:41 UTC
