gearbox joint does not work correctly
Hello everyone. I am a user of Gazebo & ROS.
I am using mimicjointplugin to open/close a robot gripper. This works correctly (An example motion is here https://youtu.be/SqPNVJqgZns).
My xacro file is here link. Please see lines 125 to 131.
<gazebo>
<plugin name="crane_x7_gripper_mimic_joint" filename="libroboticsgroup_gazebo_mimic_joint_plugin.so">
<joint>${name}_finger_a_joint</joint>
<mimicJoint>${name}_finger_b_joint</mimicJoint>
<multiplier>1</multiplier>
So mimicjointplugin is not official plugin of Gazebo, I am trying to use gearbox joint instead of the plugin. This works not correctly (An example motion is here https://youtu.be/-G1jMrhYzSc).
I think the fingerblink couldn't follow the motion of fingerbaselink.
I add a gearbox joint and comment out the plugin in the xacro file.
<gazebo>
<joint name="${name}_finger_gearbox" type="gearbox">
<parent>${name}_finger_a_link</parent>
<child>${name}_finger_b_link</child>
<gearbox_reference_body>${name}_base_link</gearbox_reference_body>
<gearbox_ratio>1</gearbox_ratio>
<axis>
<xyz>0 1 0</xyz>
</axis>
<axis2>
<xyz>0 1 0</xyz>
</axis2>
<gazebo>
Where should I fix in the xacro file?
Thanks.
Asked by ShotaAk on 2019-05-07 02:53:47 UTC
Is it working now? I think I am facing the same issue in gazebo 9. But it is working properly in gazebo 11
Asked by manoj on 2021-02-21 07:29:42 UTC
