issues installing gazebo
I am working on Ubuntu 16.04 and I want to install gazebo on it. But if I try sudo apt-get install ros-kinetic-gazebo-ros
it says:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-kinetic-gazebo-ros : Depends: ros-kinetic-gazebo-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Or if I try sudo apt-get install gazebo8
I get this:
gazebo8 : Depends: libgazebo8 (= 8.0.0-1~xenial) but it is not going to be installed
Depends: libsdformat5 but it is not going to be installed
Depends: gazebo8-common (= 8.0.0-1~xenial) but 8.6.0-1~xenial is to be installed
Recommends: gazebo8-plugin-base but it is not going to be installed
I had gazebo7 before but I removed it, but it still does not work. I tried everything to solve the broken packages problem but nothing worked. And I looked multiple times if I deleted gazebo7 properly and could not find anything of it. So what am I doing wrong? So one more thing: if I try sudo apt-get install ros-kinetic-desktop-full
it says:
ros-kinetic-desktop-full : Depends: ros-kinetic-simulators but it is not going to be installed
Asked by S. Yildiz on 2019-05-14 04:18:01 UTC
Sorry for not giving a complete answer, but check this link:
https://appuals.com/fix-unable-correct-problems-held-broken-packages/
This is not a gazebo specific problem, so you can try to google "Unable to correct problems, you have held broken packages." to see more alternatives.
Asked by rasecg3 on 2019-05-14 14:57:10 UTC
