Neither "gz topic --hz ~/scene" nor "gz topic --echo ~/scene" work
Hi all,
on gzweb sometimes I get a gray screen because it doesn't retrieve the scene from gzserver.
Even if gzserver is running properly, the commands mentioned on the title doesn't respond.
If I try different topics it works fine, so my question is: how to retrieve the scene?
If I run gz topic --info /gazebo/default/scene
I see no publishers.
Type: gazebo.msgs.Scene
Publishers:
Subscribers:
172.18.0.2:44339
172.18.0.8:36139
If I try gz topic --list | grep scene
I can see /gazebo/default/scene
, but gz topic --hz "~/scene"
never responds and gz topic --echo "~/scene"
just finishes with code 0
but without any messages.
If I try gz topic --hz "~/pose/local/info"
it works.
If I try gz topic --verbose -e "~/scene"
or gz topic --verbose -e "/gazebo/default/scene"
I get:
[Msg] Waiting for master.
[Msg] Publicized address: 172.18.0.8
[Err] [gz_topic.cc:190] Unable to get message type for topic[~/scene]
[Err] [gz_topic.cc:190] Unable to get message type for topic[/gazebo/default/scene]
I've tried export GAZEBO_MASTER_URI=http://172.18.0.8:11345
based on the previous output but it doesn't solve the problem
I noticed that if I run gzclient
, then gz topic --info /gazebo/default/scene
shows a publisher, but still the commands gz topic --verbose -e "~/scene"
and gz topic --hz "~/scene"
don't work.
Does anybody know how to force the scene to be published?
Asked by Ruben on 2019-05-17 13:05:38 UTC
