Difference between gzclient, gzserver and gazebo
When I run ros2 launch turtlebot3_gazebo turtlebot3_world.launch.py
, gazebo is launched.
Then, I run:
user@ubuntu:~/ros2_ws$ lsof -iUDP | grep gazebo
gazebo 27889 user 9u IPv4 496548 0t0 UDP *:7400
gazebo 27889 user 10u IPv4 496554 0t0 UDP *:7418
gazebo 27889 user 11u IPv4 496560 0t0 UDP *:7419
gazebo 27889 user 12u IPv4 496563 0t0 UDP *:52459
user@ubuntu:~/ros2_ws$ lsof -iUDP | grep gzserver
gzserver 27902 user 9u IPv4 496548 0t0 UDP *:7400
gzserver 27902 user 10u IPv4 496554 0t0 UDP *:7418
gzserver 27902 user 11u IPv4 496560 0t0 UDP *:7419
gzserver 27902 user 12u IPv4 496563 0t0 UDP *:52459
gzserver 27902 user 15u IPv4 496615 0t0 UDP *:7400
gzserver 27902 user 16u IPv4 496623 0t0 UDP *:7422
gzserver 27902 user 17u IPv4 496631 0t0 UDP *:7423
gzserver 27902 user 18u IPv4 496634 0t0 UDP *:48586
gzserver 27902 user 41u IPv4 497324 0t0 UDP *:11317
gzserver 27902 user 42u IPv4 497329 0t0 UDP *:11318
gzserver 27902 user 52u IPv4 495547 0t0 UDP *:7400
gzserver 27902 user 53u IPv4 495555 0t0 UDP *:7424
gzserver 27902 user 54u IPv4 495563 0t0 UDP *:7425
gzserver 27902 user 55u IPv4 495566 0t0 UDP *:38077
gzserver 27902 user 62u IPv4 498712 0t0 UDP *:7400
gzserver 27902 user 63u IPv4 498720 0t0 UDP *:7426
gzserver 27902 user 64u IPv4 498728 0t0 UDP *:7427
gzserver 27902 user 65u IPv4 498731 0t0 UDP *:48999
gzserver 27902 user 72u IPv4 498740 0t0 UDP *:7400
gzserver 27902 user 73u IPv4 498748 0t0 UDP *:7428
gzserver 27902 user 74u IPv4 498756 0t0 UDP *:7429
gzserver 27902 user 75u IPv4 498759 0t0 UDP *:45287
gzserver 27902 user 82u IPv4 495579 0t0 UDP *:7400
gzserver 27902 user 83u IPv4 495587 0t0 UDP *:7430
gzserver 27902 user 84u IPv4 495595 0t0 UDP *:7431
gzserver 27902 user 85u IPv4 495598 0t0 UDP *:49441
user@ubuntu:~/ros2_ws$ lsof -iUDP | grep gzclient
gzclient 27903 user 9u IPv4 496548 0t0 UDP *:7400
gzclient 27903 user 10u IPv4 496554 0t0 UDP *:7418
gzclient 27903 user 11u IPv4 496560 0t0 UDP *:7419
gzclient 27903 user 12u IPv4 496563 0t0 UDP *:52459
gzclient 27903 user 24u IPv4 497351 0t0 UDP *:11317
gzclient 27903 user 25u IPv4 497356 0t0 UDP *:11318
What is the difference between gzclient
, gzserver
, gazebo
? I understand that gzclient
is the gazebo GUI, but I don't understand why gazebo
pops up as another process. Why does gzclient
and gazebo
share some same ports as well?
Also, why does gzserver
use so many ports? Is it because it is responsible for spinning up several nodes in the turtlebot3_world.launch.py
file?
Asked by wan_da on 2019-06-17 03:04:55 UTC
