Gazebo crash on launch on VMWare on Mac, Ubuntu 16.04, Kinetic
I know that this comes up a lot and there are answers but I've not been able to solve this. Let me give my specific case:
- macbook pro
- vmware fusion 11
- vm configured with 8gig, 3d acceleration
- ubuntu 16.04
- full kinetic install (includes gazebo)
- simple simple simulation case crashes
Do you have any clue that could help me troubleshoot?
/catkin_ws/src$ roslaunch turtlebot3_gazebo turtlebot3_empty_world.launch
... logging to /home/pitosalas/.ros/log/56ff08e4-94f1-11e9-866a-000c29ecabe0/roslaunch-ubuntu-3553.log
Press Ctrl-C to interrupt
started roslaunch server http://localhost:32807/
SUMMARY
PARAMETERS
* /robot_description: <?xml version="1....
* /rosdistro: kinetic
* /rosversion: 1.12.14
* /use_sim_time: True
NODES
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
spawn_urdf (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [3566]
setting /run_id to 56ff08e4-94f1-11e9-866a-000c29ecabe0
process[rosout-1]: started with pid [3581]
process[gazebo-2]: started with pid [3588]
process[gazebo_gui-3]: started with pid [3604]
process[spawn_urdf-4]: started with pid [3612]
[ INFO] [1561209990.986140757]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1561209991.017806263]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1561209991.259239987]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1561209991.262437751]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1561209993.643635114, 0.025000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1561209993.761162093, 0.121000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1561209996.612253261, 0.375000000]: Laser Plugin: Using the 'robotNamespace' param: '/'
[ INFO] [1561209996.612348034, 0.375000000]: Starting Laser Plugin (ns = /)
[ INFO] [1561209996.628284054, 0.375000000]: Laser Plugin (ns = /) <tf_prefix_>, set to ""
[ INFO] [1561209996.667784559, 0.375000000]: Physics dynamic reconfigure ready.
[ INFO] [1561209996.676147365, 0.375000000]: Physics dynamic reconfigure ready.
[ INFO] [1561209996.734885622, 0.375000000]: Starting plugin DiffDrive(ns = //)
[ INFO] [1561209996.735131905, 0.375000000]: DiffDrive(ns = //): <rosDebugLevel> = na
[ INFO] [1561209996.739759221, 0.375000000]: DiffDrive(ns = //): <tf_prefix> =
[ INFO] [1561209996.770172719, 0.375000000]: DiffDrive(ns = //): Advertise joint_states
[ INFO] [1561209996.783261442, 0.375000000]: DiffDrive(ns = //): Try to subscribe to cmd_vel
[ INFO] [1561209996.815107906, 0.375000000]: DiffDrive(ns = //): Subscribe to cmd_vel
[ INFO] [1561209996.827031593, 0.375000000]: DiffDrive(ns = //): Advertise odom on odom
[spawn_urdf-4] process has finished cleanly
log file: /home/pitosalas/.ros/log/56ff08e4-94f1-11e9-866a-000c29ecabe0/spawn_urdf-4*.log
VMware: vmw_ioctl_command error Invalid argument.
Aborted (core dumped)
[gazebo_gui-3] process has died [pid 3604, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/pitosalas/.ros/log/56ff08e4-94f1-11e9-866a-000c29ecabe0/gazebo_gui-3.log].
log file: /home/pitosalas/.ros/log/56ff08e4-94f1-11e9-866a-000c29ecabe0/gazebo_gui-3*.log
^C[gazebo-2] killing on exit
[gazebo-2] escalating to SIGTERM
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Asked by Pitosalas on 2019-06-22 08:32:43 UTC
I just found this and it seems to solve this particular problem for now:
export SVGA_VGPU10=0
Not sure if that is different from turning off 3d acceleration in VMWare.
Asked by Pitosalas on 2019-06-22 08:45:18 UTC
It is different, it basically downgrades support of OpenGL to 2.1. Turning off 3D acceleration from VMWare would basically run rendering code entirely on the CPU.
Asked by Samahu on 2020-04-16 10:33:05 UTC
