How to create a sr_tactile_sensor in gazebo ?
I am quite a beginner to the gazebo. I am trying to add srtactilesensor to a link in my robot in gazebo. I have tried to create a new link as a dummy for my sensor and added a fixed joint choosing the link that is supposed to be attached to sensor as parent and the dummy link as child and choose the joint to be fixed. later I have added gazebo reference to that sensor link as follows :
<gazebo reference="tactile_1">
<sensor type="tactile" name="sr_tactile_virtual_1">
<pose>0.0 0.0 0.0 0.0 0 0</pose>
<update_rate>10</update_rate>
<ray>
<range>
<min>0.00</min>
<max>100.0</max>
</range>
</ray>
<plugin name="sr_tactile_virtual_1" filename="libblock_sr_tactile_virtual.so">
<topicName>/sr_tactile_sensor_1</topicName>
<frameName>sr_tactile_sensor_1</frameName>
<alwaysOn>true</alwaysOn>
<gaussianNoise>0.00</gaussianNoise>
<updateRate>10.0</updateRate>
Doing so I have been having an error to spawn my robot in gazebo and I believe the error is caused because of the way I have added the sensor to my robot model. So i am wondering whether I actually need to create a dummy link and dummy joint to add the sensor or can I directly add the sensor to whatever link I want it to be attached to using gazebo reference like I did above ? I have gone through the gazeboism tutorials and I was a bit confused about this. Kindly anyone please clarify me this. For the sake of clarity I am also adding the snap of my sdf file where I have created a dummy link and joint here.
<link name="tactile_sensor_1">
<collision>
<box size="${tactile_link} ${tactile_link} ${tactile_link}"/>
<visual>
<material name="red"/>
<mass value="1e-5" />
<inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6" />
Asked by microbot on 2019-06-30 08:02:53 UTC
