Gazebo ROS diff drive controller cmd_vel timeout
I'm using ROS melodic and Gazebo 9.9.0 on an Ubuntu 18.04.2 LTS.
I have defined this diff drive controller for a Pioneer 2DX that I use in Gazebo. The robot comes from Gazebo library, and I have changed its controller for this one:
<plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so">
<alwaysOn>true</alwaysOn>
<updateRate>100</updateRate>
<leftJoint>left_wheel_hinge</leftJoint>
<rightJoint>right_wheel_hinge</rightJoint>
<torque>20</torque>
<commandTopic>mybot/cmd_vel</commandTopic>
<odometryTopic>mybot/odom_diffdrive</odometryTopic>
<rosDebugLevel>1</rosDebugLevel>
<publishWheelTF>false</publishWheelTF>
<publishOdomTF>true</publishOdomTF>
<publishWheelJointState>false</publishWheelJointState>
<wheelAcceleration>0</wheelAcceleration>
<wheelTorque>5</wheelTorque>
<odometrySource>world</odometrySource>
<publishTf>1</publishTf>
<robotBaseFrame>chassis</robotBaseFrame>
<wheelSeparation>0.39</wheelSeparation>
<wheelDiameter>0.15</wheelDiameter>
I'm new in ROS development, and I have read that most mobile base drivers will time out and stop the robot if they don't receive at least several messages per second.
Reading Diff Drive Controller ROS API, I have found that there is a parameter called cmd_vel_timeout
that will do what I want to do.
Is there something similar in the libgazeborosdiffdrive.so that will stop the robot after no receiving cmdvel messages for n seconds?
By the way, now, when I press Ctrl.+C, the robot doesn't stop. It seems that the robot doesn't any timeout value configured.
Asked by VansFannel on 2019-07-09 03:52:05 UTC
