Problem of building ros server in Gazebo model plugin
I am now building a ros server node in a gazebo plugin and got an error:
error: no matching function for call to ‘ros::NodeHandle::advertiseService(const char [12], bool (gazebo::JointController::*)(gazebotutorials::mysrv::Request&, gazebotutorials::mysrv::Response&))’ this->myservice = this->rosNode->advertiseService("/addserver", &JointController::addd);
I think this is because I did not set up the argument types correctly, I google for a long time and found nothing similar to my code. Any help would be a life saver for me, thanks in advanced!
here's some pieces of my code:
class JointController : public ModelPlugin
/// \brief Constructor
public: JointController() {}
public: virtual void Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
  // Store the model pointer for convenience.
  this->model = _model;
  // Initialize ros, if it has not already bee initialized.
  if (!ros::isInitialized())
    int argc = 0;
    char **argv = NULL;
    ros::init(argc, argv, "gazebo_client",
        ros::init_options::NoSigintHandler);
  // Create our ROS node. This acts in a similar manner to
  // the Gazebo node
  this->rosNode.reset(new ros::NodeHandle("gazebo_client"));
  //ros::NodeHandle n;
  //FITNESS publisher
  this->fitness_pub =this->rosNode->advertise<std_msgs::Float64>("/fitness", 100);
  //Service Node
  this->my_service = this->rosNode->advertiseService("/add_server", &JointController::addd);
  // Spin up the queue helper thread.
  this->rosQueueThread =
    std::thread(std::bind(&JointController::QueueThread, this));
public: bool addd(gazebo_tutorials::mysrv::Request& req,
         gazebo_tutorials::mysrv::Response& res)
  res.sum = req.a + req.b;
  ROS_INFO("request: x=%ld, y=%ld", (long int)req.a, (long int)req.b);
  ROS_INFO("sending back response: [%ld]", (long int)res.sum);
  return true;
Asked by stupid on 2019-07-20 16:19:02 UTC
Hi. You would have to pass "this" pointer also as an argument when defining the serviceserver object like so,
//Service Node
this->my_service = this->rosNode->advertiseService("/add_server", &JointController::addd, this);
Please refer this link as it explains using member functions of classes as callback functions. http://wiki.ros.org/roscpp_tutorials/Tutorials/UsingClassMethodsAsCallbacks
Hope this helps.
Asked by Cyberman on 2019-10-17 10:09:41 UTC
