Gazebo doesn't upload changes in code
C:\fakepath\ddrobot_gazebo.launch(/upfiles/15650416706618589.launch)
I'm following the course gazebo in 5 mins (the construct ) & used the attached files which belong to a project in ch2 book ros robotics by example because it worked with me
I find the problem that when I change in the file .world in simple things as models or their functions, I hardly find the change in codes as an output in gazebo scene & I found errors in launching & they are solved partially
when I created a model and referred to it in the .world file it wasn't showing any changes as the code changes for both default gazebo models and my models, what may cause this problem?
I'm using the latest version of VirtualBox with ubuntu 16.4 - gazebo 7!
ddrobot.world
image description image description
Asked by nouran_g7 on 2019-08-05 17:01:22 UTC
Show us the changed file. How it look while it worked without errors, then how did you change it, and then the errors, please.
Copy the code in your question and use the code formatting.
Asked by kumpakri on 2019-08-08 07:05:49 UTC
before changing are attached as pics , after changing attached as files
the error is process[gazebo-1]: started with pid [27378] process[gazebo_gui-2]: started with pid [27383] process[spawn_urdf-3]: started with pid [27388] [gazebo-1] process has died [pid 27378, exit code 255, cmd /home/noura/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/gzserver -e ode /home/noura/catkin_ws/src/ros_robotics/worlds/ddrobot.world __name:=gazebo __log:=/home/noura/.ros/log/94cdf488-b70a-11e9-9f19-08002739b
Asked by nouran_g7 on 2019-08-09 06:55:01 UTC
past the code as a text into the question. The file is not accessible and nobody is going to copy a letter by letter of your code by hand to use his favorite editor to narrow down the problem. Also add the link to the tutorial you follow. Make it easy for people to help or nobody is going to help you. Look at other question how people do it.
Asked by kumpakri on 2019-08-13 07:55:10 UTC
