Gazebo freezes on Save As with too many cameras
I have installed Gazebo 9 with ROS melodic on Ubuntu 18.04. I keep getting following unexpected behaviour:
- Create a new world in Gazebo (only ground plane and sun)
- Add an object to the world (any object e.g. a car)
- Add cameras to the world (4 cameras needed, from standard library)
- File -> Save As... or Ctrl+Shift+S
- The program freezes and the saving window does not show up
- gzclient process starts using 100% CPU
It is possible to Alt+F4 to return to the world editor. The only thing showing up in the terminal: Gtk-Message: 16:30:04.390: GtkDialog mapped without a transient parent. This is discouraged.
What can be the cause? How to fix this?
Asked by CheddarChopper on 2019-08-06 09:26:59 UTC
I dont know if it solves your problem, but I had a similar problem with gazebo freezing if I would press save as.
I solved it by opening gazebo with sudo gazebo in the shell.
I hope this helps.
Asked by Zeckurbo on 2020-12-07 09:43:37 UTC
i have the same question
Asked by Lays on 2019-08-20 18:53:30 UTC
Brother i have the same question. Help me if you got your answer.
Asked by Abdullah Razzaq on 2020-03-31 16:25:42 UTC
