Unable to install gzweb on ubuntu 18.04
I first installed gazebo9 and verified it runs after entering 'gazebo'
Then I followed the setup procedure for installing gzweb from here: http://gazebosim.org/tutorials?cat=gzweb&tut=gzweb_install&ver=1.9%2B
The versions of the dependencies are:
- libjansson-dev is already the newest version (2.11-1).
- libboost-dev is already the newest version (1.65.1.0ubuntu1).
- imagemagick is already the newest version (8:6.9.7.4+dfsg-16ubuntu6.7).
- libtinyxml-dev is already the newest version (2.6.2-4).
- mercurial is already the newest version (4.5.3-1ubuntu2.1).
- cmake is already the newest version (3.10.2-1ubuntu2.18.04.1).
- build-essential is already the newest version (12.4ubuntu1).
- nodejs is already the newest version (8.10.0~dfsg-2ubuntu0.4).
- npm is already the newest version (3.5.2-0ubuntu4)
running './deploy.sh -m' yielded the error:
CMake Error at CMakeLists.txt:38 (find_package):
By not providing "Findgazebo.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "gazebo", but
CMake did not find one.
One post indicated the way to fix this error is to install 'libgazebo9-dev'. Unfortunately, installing this will remove the following packages:
libcurl4-gnutls-dev libssl1.0-dev node-gyp nodejs-dev npm
Another post indicated the following commands were able to fix his similar error:
curl -sL https://deb.nodesource.com/setup_8.x | sudo bash -
sudo apt-get install -y nodejs
This caused version 8.16.1 of nodejs to be loaded instead of 8.10.0. Now, however, when I try to install npm, it indicates it can't install because there are unmet dependancies:
npm : Depends: nodejs but it is not going to be installed
Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
Depends: node-which but it is not going to be installed
And nodejs won't install without nodejs-dev, which won't install without libssl1.0-dev. If I then install libssl1.0-dev, I see that it will uninstall 'libgazebo9-dev'. So if I proceed with this, nodejs, nodejs-dev and libssl1.0-dev are all installed, but libgazebo9-dev is uninstalled and I again get the same error I originally got when I try to run ./deploy.sh -m
Does gzweb not work with gazebo9 on ubuntu 18.04, or is this some setup issue I have? Thanks
Asked by dmcd2356 on 2019-08-20 18:41:54 UTC
By the way, the full error comment that I get is:
Could not find a package configuration file provided by "gazebo" with any
of the following names:
gazeboConfig.cmake
gazebo-config.cmake
Add the installation prefix of "gazebo" to CMAKE_PREFIX_PATH or set
"gazebo_DIR" to a directory containing one of the above files. If "gazebo"
provides a separate development package or SDK, be sure it has been
installed.
Neither of these files are present in the /usr/share/gazebo-9 directory. This only consists of a setup.sh file and the subdirectories: media, models and worlds, none of which contain the cmake files either.
Also, my environment does not include either of the CMAKE_xxx_PATH settings. Should these be set to something?
Asked by dmcd2356 on 2019-08-21 11:11:05 UTC
Hey just following up on this. I am running into the same exist issue.
Asked by vinnnyr on 2020-10-16 09:40:55 UTC
