How to get the position of a model in World plugin
I have this code in my World plugin:
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
            auto model = myWorldPtr->ModelByName("robot1");
            if (model != NULL)
                ignition::math::Pose3d position = model->WorldPose();
                ignition::math::Vector3d pos = position.Pos();
                ROS_INFO("TeleopRobot::joyCallback -> linear.x: %d", pos.X());
but pos.X() has always the same value although my model is moving.
I have seen previous solutions here, but neither of them works. I just want to know where my model is while moving.
Any ideas?
Asked by PeterHer on 2019-09-17 04:16:56 UTC
Is your model moving in x axis?
Asked by kumpakri on 2019-09-17 08:01:48 UTC
Yes, in both X and Y-axis
Asked by PeterHer on 2019-09-17 08:06:16 UTC
Although my model is moving, pos.X() is always something like this output:
[ INFO] [1568774337.884405056, 16.421000000]: TeleopRobot::joyCallback -> linear.x: 1880747911 That is stranger because my model is in a field of x: -4.5 to 4.5, y: -3.5 to 3.5
Asked by PeterHer on 2019-09-17 21:36:54 UTC
I'm sorry my bad, code should be:
double position = model->RelativePose().Pos().X(); ROS_INFO("TeleopRobot::joyCallback -> linear.x: %f", position); I displayed an integer, should be a double :-(
Asked by PeterHer on 2019-09-17 21:52:05 UTC
case closed
Asked by PeterHer on 2019-09-17 21:52:20 UTC
How exactly did you get this method to be called every update?
Asked by LakeWorthB on 2020-03-25 09:32:18 UTC
Use ConnectUpdateWorldBegin like on this tutorial: http://gazebosim.org/tutorials?tut=plugins_model&cat=write_plugin
Asked by chapulina on 2020-03-25 11:38:06 UTC
