Setting Gui in System plugin and order of loading plugins
I want to try to set the Gui while running the simulator like this:
namespace gazebo { class SystemGUI : public SystemPlugin {
private: rendering::UserCameraPtr userCam;
private: std::vector<event::ConnectionPtr> connections;
public: SystemGUI() : SystemPlugin() { }
public: virtual ~SystemGUI()
this->connections.clear();
this->userCam.reset();
public: void Load(int /*_argc*/, char ** /*_argv*/)
this->connections.push_back(
event::Events::ConnectPreRender(
std::bind(&SystemGUI::Update, this)));
private: void Init()
private: void Update()
if (!this->userCam)
this->userCam = gui::get_active_camera();
if (this->userCam != NULL)
const ignition::math::Angle &yaw = 0;
this->userCam->Yaw(yaw);
rendering::ScenePtr scene = rendering::get_scene();
if (!scene || !scene->Initialized())
return;
if (scene->GetVisual("ground_plane"))
std::cout << "Has ground plane visual\n";
GZREGISTERSYSTEM_PLUGIN(SystemGUI) }
but unfortunately the Yaw is not set to 0. Any idea how I can set the Gui while my simulation is running? I run Gazebo like this: gzclient -g libsimulator_system.so
The main goal is to run the whole simulator like: roslaunch simulator_world simulator.launch My world file ends with:
But this way the System plugin will exit prematurely [ INFO] [1568787274.691299252]: Finished loading Gazebo ROS API Plugin. [ INFO] [1568787274.692145228]: waitForService: Service [/gazebo/setphysicsproperties] has not been advertised, waiting... [ INFO] [1568787274.743609739]: waitForService: Service [/gazebogui/setphysicsproperties] has not been advertised, waiting... [ INFO] [1568787274.744664911]: Finished loading Gazebo ROS API Plugin. [ INFO] [1568787277.237475087]: SystemPlugin::SystemGUI [ INFO] [1568787277.237626131]: SystemPlugin::Exit SystemGUI [ INFO] [1568787277.248128220]: WorldPlugin::Enter plugin [ INFO] [1568787277.248723325]: WorldPlugin::Init -> IsLoaded: 1 [ INFO] [1568787277.252055953]: WorldPlugin::Init -> groundplane
Thanks in advance
Asked by PeterHer on 2019-09-18 07:31:06 UTC
