Gazebo9, no methods is working to change urdf colors
Hi, I tried everything to change color of links in Gazebo9-ROS Melodic. Nothing works, I already followed official guides as well as every other question in the forum. Can you explain me what's wrong with my methods?
METHOD 1: In "materials.xacro" :
<?xml version="1.0"?>
<robot>
<material name="myblue">
<color rgba="0.0 0.0 0.8 1.0"/>
</robot>
In mybot.xacro: Hi, I tried everything to change color of links in Gazebo9-ROS Melodic. Nothing works, I already followed official guides as well as every other question in the forum. Can you explain me what's wrong with my methods?
<robot>
</robot>
In mybot.xacro:
> <?xml version="1.0"?> <link
> name="chassis_front1">
> <inertial>
> <!-- various things -->
> </inertial>
> <collision name='collision_front1'>
> </collision>
> <visual name='chassis_visual_front1'>
> <origin xyz="${x_or} ${y_or} 0" rpy=" 0 0 0"/>
> <geometry>
> </geometry>
> </visual>
> <color name="myblue" /> </link>
I also tried to put
METHOD 2:
in a file named "mybot.gazebo":
<gazebo reference="chassis_front1">
<material>Gazebo/Red</material>
But, also this time, component color did not change. What's wrong with it?
Asked by Tobi92 on 2019-09-19 03:30:41 UTC
You can try
<script>
<name>Gazebo/Red</name>
</script>
Asked by kumpakri on 2019-09-19 05:17:21 UTC
Thank you, unfortunately nothing changes... I tried to put this string in mybot.xacro (and within visual and within link and external to link with a reference) and I tried to add it in mybot.gazebo too.. Nothing
Asked by Tobi92 on 2019-09-19 08:51:45 UTC
Try deleting the "name" from your visual tags, this worked for me.
NO:
YES:
<visual>
See a full working example here.
Asked by Oscar Lima on 2021-03-23 13:43:21 UTC
did you ever find the solution to this? I'm having the same problem
Asked by Emanuele on 2020-11-10 04:38:16 UTC
