Wind Feature in Gazebo 8.
I am using Gazebo 8. I can see Wind option and it is enabled. But no matter what value I give for the linear velocity for wind (in x, y and z direction), nothing happens.
How to blow the wind in whole Environment in Gazebo 8?
How strong can the winds be? Can it blow away the default spherical, cubical objects available in Gazebo?
Asked by bumzo9436 on 2019-09-22 21:52:43 UTC
Hi, were you able to find a solution to this problem
Asked by Withered_Shadow on 2020-05-21 08:58:09 UTC
Does your object has the enable wind tag set to true? It is switched off by default according to the documentation.
Asked by kumpakri on 2019-09-26 04:08:26 UTC
