Gazebo bumper sensor states msg shows no output
I have a simple robot with two wheels and I am trying to add bumper sensors on each side. The goal is to create a blind robot which has a bumper/contact sensor to sense the walls in its world and then make it navigate through the world.
I can see the topic /state_bumper
in rostopic list
and echo it, but I cannot see any values in states msg as shown below:
$ rostopic echo /state_bumper
header:
seq: 75
stamp:
secs: 480
nsecs: 588000000
frame_id: "world"
states: []
header:
seq: 76
stamp:
secs: 480
nsecs: 588000000
frame_id: "world"
states: []
Please help me understand where am I going wrong.
I have only shown below the bumper sensor-related code and cut out the robot links codes. I have two separate amprobot.xacro and amprobot.gazebo files which I then convert to urdf and sdf files to see the collision tag names and make sure they are the same. This was indicated as a solution in similar questions but does not work for me. I use these commands to convert the files:
$ rosrun xacro xacro -o amp_robot.urdf amp_robot.xacro
$ gz sdf -p amp_robot.urdf > amp_robot.sdf
Robot URDF:
<?xml version="1.0" ?>
<!-- | This document was autogenerated by xacro from amp_robot.xacro | -->
<!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
<!-- x-green y-red z-blue - for all values - depending on where robot is facing - generally x-->
<robot name="amp_robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
<gazebo>
<gazebo reference="bumper_link">
<selfCollide>false</selfCollide>
<sensor name="bump_sensor" type="contact">
<update_rate>15.0</update_rate>
<contact>
<collision>robot_footprint_fixed_joint_lump__bumper_collision_collision_3</collision>
<!--<topic>__default_topic__</topic>-->
<topic>state_bumper</topic>
</contact>
<plugin filename="libgazebo_ros_bumper.so" name="state_gazebo_ros_bumper_controller">
<alwaysOn>true</alwaysOn>
<updateRate>15.0</updateRate>
<bumperTopicName>state_bumper</bumperTopicName>
<frameName>world</frameName>
<link name="bumper_link">
<origin rpy="0 0 0" xyz="0 0 0"/>
<mass value="1e-5"/>
<inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6"/>
<visual>
<origin rpy="0 0 0" xyz="0.2 0 0"/>
<box size="0.1 0.05 0.05"/>
<material name="DarkGrey"/>
<collision>
<joint name="bumper_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.08 0 0.04"/>
<axis xyz="0 1 0"/>
<!--<insert_block name="origin"/>-->
<parent link="chassis"/>
<child link="bumper_link"/>
Robot SDF
<collision name='robot_footprint_fixed_joint_lump__bumper_link_collision_3'>
<pose frame=''>0.08 0 0.04 0 -0 0</pose>
<size>0.1 0.05 0.05</size>
<surface>
<contact>
<ode/>
</contact>
<friction>
<ode/>
</friction>
</surface>
<visual name='robot_footprint_fixed_joint_lump__bumper_link_visual_3'>
<pose frame=''>0.28 0 0.04 0 -0 0</pose>
<script>
<uri>__default__</uri>
<name>__default__</name>
</script>
<velocity_decay/>
<gravity>1</gravity>
<velocity_decay/>
<sensor name='bump_sensor' type='contact'>
<update_rate>15</update_rate>
<visualize>1</visualize>
<contact>
</contact>
<plugin name='state_gazebo_ros_bumper_controller' filename='libgazebo_ros_bumper.so'>
Ubuntu:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
ROS environment:
$ env | grep ROS
ROS_ROOT=/opt/ros/kinetic/share/ros
ROS_PACKAGE_PATH=/home/jit/catkin_ws/src:/opt/ros/kinetic/share
ROS_VERSION=1
ROSLISP_PACKAGE_DIRECTORIES=/home/jit/catkin_ws/devel/share/common-lisp
ROS_DISTRO=kinetic
ROS_ETC_DIR=/opt/ros/kinetic/etc/ros
Gazebo:
$ gazebo -v
Gazebo multi-robot simulator, version 7.0.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
http://gazebosim.org
Asked by jatinm on 2019-09-29 14:18:25 UTC
