How to modify a model plugin to publish data to a rostopic or ros node?
I am trying to work with gazebomotormodel.cpp. I need to visual some data that is calculated inside the plugin such a force, drag_torque etc. Is there a way i can publish this data to a topic or node so that i can visualize it using rqt.
P.S. - I am working on ROS kinetic with gazebo 7
Adding the .cpp
file for reference.
C:\fakepath\gazebomotormodel.cpp
Asked by zaccer on 2019-10-07 04:46:14 UTC
Sure, just initialize the ROS node inside the load function
if (!ros::isInitialized())
int argc = 0;
char **argv = NULL;
ros::init(argc, argv, node_name,
ros::init_options::NoSigintHandler);
// Create ROS node.
this->rosNode.reset(new ros::NodeHandle( node_name ));
and create a publisher
this->rosPub = this->rosNode->advertise<std_msgs::Float64>(topic_name,1);
Then you can access the class variable this->rosPub
from within the plugin and send the messages.
EDIT
Include ROS at the top of the header file gazebo_motor_model.h
#include "ros/ros.h"
Declare the class variables inside the header file
namespace gazebo {
class GazeboMotorModel : public MotorModel, public ModelPlugin {
private: std::unique_ptr<ros::NodeHandle> rosNode;
private: ros::Publisher rosPub;
initialize the ROS node inside the Load function of the plugin inside the gazebo_motor_model.cpp
file
int argc = 0;
char **argv = NULL;
ros::init(argc, argv, "my_ros_node",
// Create ROS node.
this->rosNode.reset(new ros::NodeHandle( "my_ros_node" ));
initialize the ros publisher right under the ROS node initialization
this->rosPub = this->rosNode->advertise<std_msgs::Float64>("my_ros_topic",1);
note that the message type (here std_msgs::Float64
) must be edited to match your topics message type.
Now you can send the message anywhere in your update function
std_msgs::Float64 msg;
msg.data = 15.3;
this->rosPub.publish(msg);
Asked by kumpakri on 2019-10-07 05:24:46 UTC
does the node need to be initialized in a separate script or in the same plugin file? Is there some example I can take reference of?
Asked by zaccer on 2019-10-07 05:52:03 UTC
You do it inside the plugin from which you want to get the information out to ROS.
Asked by kumpakri on 2019-10-07 06:32:04 UTC
After implementing the code, i tried to compile it but got the error ‘ros’ has not been declared
. Any suggestions?
Asked by zaccer on 2019-10-07 06:42:51 UTC
The gazebo plugins typically have a source code .cpp
inside the /src
folder and the header file .h
or .hh
of the same name inside the /include
folder. You need to tell the interpreter to look into the ROS library. That is typically done inside the header file. The class variables (rosNode
and rosPub
in the example) are also typically declared in the header file. See the new edit in my answer.
Asked by kumpakri on 2019-10-07 07:09:30 UTC
private: std::unique_ptrros::NodeHandle rosNode; private: ros::Publisher rosPub; Do I need to modify the ros.h file to include the above class.
And how would i use the this->rospub
class to publish lets say force
inside UpdateForcesAndMoments
function.
I should have mentioned, I am relatively new to ROS hence the struggle with such basic stuff.
Asked by zaccer on 2019-10-07 07:18:55 UTC
See if the current edit has all the answers you need. I think I addressed them all. Point to me what stays unclear still.
Asked by kumpakri on 2019-10-07 07:23:17 UTC
Your source code is named gazebo_motor_model.cpp
so your header file inside the /include
folder is named gazebo_motor_model.h
. That is the header file you need to modify with the three lines I showed you above.
Asked by kumpakri on 2019-10-07 07:37:03 UTC
When you look inside the Gazebo 7 API documentation (Physics --> Joint --> GetVelocity()
) You can see it returns a scalar number in double format, so, actually, the example with Float64 message type could be used if you are creating your own topic to publish to.
In that case also include the message type somewhere in your code (you can do it in source code or header file alike)
#include <std_msgs/Float64.h>
Asked by kumpakri on 2019-10-07 07:46:28 UTC
Thanks a lot for the detailed explanation.
Asked by zaccer on 2019-10-07 23:33:40 UTC
I implemented the code in the gazebo_motor_model.cpp
, i was able to compile it without any error. but neither the node name nor the topic comes up during rosnode list and rostopic list.I am editing my question to include my modified gazebo_motor_model.cpp
file. Please tell me where i might be making mistake.
Asked by zaccer on 2019-10-08 00:22:12 UTC
Are you sure the correct plugin is loaded? Can you add a debug message to the Load function that would be printed in the terminal upon the simulation start, for example?
Asked by kumpakri on 2019-10-08 06:53:57 UTC
