Having trouble with Gazebo9 actor: turtle won't move!
I asked here before to get help on using heightmap. Thanks to that, now I have a beach environment for turtle detection simulation. I am planning to spawn about 20 to 40 turtles on this beach, but it will be very painful to designate trajectory for each turtle nor it will be fun to simulate detecting turtles using Fixed-Wing UAV. I am trying to randomize turtle's behavior, so I was trying to use actor plugin in Gazebo Tutorial. When I spawn the turtle model just with pose, it works fine. However, whenever I try adding plugin to the model, it does this: image description
So now I am wondering why this turtle is just facing downwards when 1) I told it to take pose 0 0 3.14, and 2) it should have been spawned on the land not hovering over the water. I was following the tutorial, but I cannot figure out which part is exactly wrong. What am I missing here?
This is how I currently set up my code: image description
Thank you
Asked by kestrel1311 on 2019-10-14 06:36:46 UTC
This might be a little late, but if you look at the source code of the plugin (https://github.com/osrf/gazebo/blob/gazebo11/plugins/ActorPlugin.cc) you'll notice the animation and trajectory parts. It looks like this Plugin is specialized for the usage with the Walking Actor person (http://gazebosim.org/tutorials?tut=actor&cat=build_robot).
You can use this source code and adapt it to your own plugin. Since you're using just a visual element without any animation, you can take those parts out and just set the pose of your actor with this->actor->SetWorldPose(pose) at the end.
This way you'll also be able to fix the issues with your rotation angles.
Asked by relffok on 2020-04-29 18:07:24 UTC
