spawning object, not visible in gazebo
Hi guys,
I am currently trying to spawn a stationnary object from a .urdf (.xacro) file, but cannot see it in gazebo. I am aware that this question was asked here already: https://answers.ros.org/question/271978/error-while-launching-robot-model/ and the problum was that there was no inertia, but I have and inertia included. Cosonle output tells me that the object was spawned sucesfully. I have followed this tutorial: https://wiki.ros.org/pr2_simulator/Tutorials/BasicPR2Controls
Console command:
rosrun gazebo_ros spawn_model -urdf -file src/sim_1/urdf/station.xacro -model station -x 0.0 -y 2.0 -z 0.695
Console output:
[INFO] [1571744435.509164]: Loading model XML from file src/sim_1/urdf/station.xacro
[INFO] [1571744435.519742]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1571744435.524289]: Calling service /gazebo/spawn_urdf_model
[INFO] [1571744435.647025]: Spawn status: SpawnModel: Successfully spawned entity
Here is my xacro file:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="station">
<!--origin xyz="0 2 0" rpy="0 0 0"/-->
<xacro:property name="cantiliver_thickness" value="0.01"/>
<xacro:property name="cantiliver_length" value="1.74"/>
<xacro:property name="cantiliver_width" value="0.08"/>
<xacro:property name="base_width" value="0.2"/>
<xacro:property name="base_length" value="1.476"/>
<xacro:property name="base_height" value="0.2"/>
<xacro:property name="leg_width" value="0.1"/>
<xacro:property name="leg_height" value="0.685"/>
<xacro:macro name="box_inertia" params="m w h d">
<mass value="${m}"/>
<inertia ixx="${m / 12.0 * (d*d + h*h)}" ixy="0.0" ixz="0.0" iyy="${m / 12.0 * (w*w + h*h)}" iyz="0.0" izz="${m / 12.0 * (w*w + d*d)}"/>
</xacro:macro>
<link name="station_body">
<mass value="10.0" />
<inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="1.0" iyz="0.0" izz="1.0" />
<visual>
<material name="silver">
<color rgba="0.75 0.75 0.75 1"/>
<box size="${base_length} ${base_width} ${base_height}"/>
<collision>
<visual>
<origin xyz="${base_length/2-leg_width/2} 0 ${-base_height/2-leg_height/2}" rpy="0 0 0" />
<box size="${leg_width} ${leg_width} ${leg_height}"/>
<collision>
<visual>
<origin xyz="${-base_length/2+leg_width/2} 0 ${-base_height/2-leg_height/2}" rpy="0 0 0" />
<collision>
<visual>
<origin xyz="${-base_length/2+leg_width/2} ${-cantiliver_length/2-base_width/2} ${-base_height/2+base_height/2}" rpy="0 0 0" />
<box size="${cantiliver_width} ${cantiliver_length} ${cantiliver_width}"/>
<collision>
<visual>
<origin xyz="${base_length/2-leg_width/2} ${-cantiliver_length/2-base_width/2} ${-base_height/2+base_height/2}" rpy="0 0 0" />
<collision>
<visual>
<origin xyz="${-base_length/2+leg_width/2} ${-cantiliver_length+leg_width/2} ${-base_height/2-leg_height/2+base_height/4-cantiliver_width/4}" rpy="0 0 0" />
<box size="${leg_width} ${leg_width} ${leg_height+base_height/2-cantiliver_width/2}"/>
<collision>
<visual>
<origin xyz="${base_length/2-leg_width/2} ${-cantiliver_length+leg_width/2} ${-base_height/2-leg_height/2+base_height/4-cantiliver_width/4}" rpy="0 0 0" />
<collision>
<visual>
<origin xyz="0 ${-cantiliver_length/2-base_width/2} ${-base_height/2+base_height/2}" rpy="0 0 0" />
<collision>
<visual>
<origin xyz="-0.315 ${-cantiliver_length/2-base_width/2} ${-base_height/2+base_height/2}" rpy="0 0 0" />
<collision>
<visual>
<origin xyz="0.315 ${-cantiliver_length/2-base_width/2} ${-base_height/2+base_height/2}" rpy="0 0 0" />
<collision>
<gazebo reference="station_body">
<material>Gazebo/LightWood</material>
</robot>
Thank you very much in advance!
Asked by chillbird on 2019-10-22 06:54:38 UTC
Hello, did you find the solution to your problem? I am having the exact same problem
Asked by LEANLALA on 2022-01-20 16:05:08 UTC
