How Gazebo process VelocityJoint data?
Hi, I'm currently trying to use ros_control and Gazebo to simulate a unicycle rover. I used Velocity Joint Interface to control the velocity of each of my joint. Here's the transmission tag in URDF file:
<joint name="holder2wheel_right">
<actuator name="motor_right">
</actuator>
And in the launch file:
  <!-- load the controllers -->
  <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
    output="screen" ns="/rover" args="left_wheel right_wheel joint_state_controller"/>
  <!-- convert joint states to TF transforms for rviz, etc -->
    <remap from="/joint_states" to="/rover/joint_states" />
  </node>
So my question is, if I set the wheel joint to have a velocity of 1 rad/s, would the wheel guarantee to have 1 rad/s?:
rospy.init_node("movement_controller_node")
left_wheel_pub = rospy.Publisher("/rover/left_wheel/command", Float64, queue_size=10)
left_wheel_pub.publish(1)
And is there a way to check the actual speed of the joint? Like a topic that is published by Gazebo?
Asked by vitsensei on 2019-11-09 07:20:52 UTC
"is there a way to check the actual speed of the joint?"
Yes.
The /imow/joint_states gazebo topic contains the velocity field for each joint loaded by the controller.
Asked by kumpakri on 2019-11-11 05:56:06 UTC
