Model is unstable in Gazebo after adding inertial tag
Hello, I am making a simple URDF for my project. I am finished with basefootprint and baselink. It seems like after adding the interial parameters to the robot, the robot became unstable after simulating in Gazebo. It started rotating about Z axis for some reason. I cannot find the solution to this. I would appreciate your help.
Code:
<?xml version="1.0" encoding="UTF-8"?>
<robot name="Auto_Bot">
    <material name="blue">
        <color rgba="0 0 0.8 1"/>
    <material name="white">
        <color rgba="1 1 1 1"/>
    <material name="red">
        <color rgba="1 0 0 1"/>
    <link name="base_footprint"/>
    <joint name="base_joint" type="fixed">
        <parent link="base_footprint"/>
        <child link="base_link"/>
        <origin xyz="0 0 0.152" rpy="0 0 0"/>
    <link name="base_link">
        <visual>
                <mesh filename="package://turtlebot3_description/meshes/Autonomous_Vehicle/meshes/V3_body_Assembly.stl" scale="0.01 0.01 0.01"/>
            <material name="blue"/>
        <collision>
            <origin rpy="0 0 0" xyz="0 0 0"/>
            <mass value="18.316"/>
            <inertia ixx="1.492" ixy="0.005" ixz="-0.012"
                     iyy="0.005" iyz="-0.012"
                     izz="-0.012"/>
</robot>
Asked by yash on 2019-11-09 11:23:46 UTC
Most probably, inertial values are not correct. change the values to
<inertia ixx="1" ixy="0" ixz="0"
         iyy="1" iyz="0"
         izz="1"/>
See the results and let me know...U can play with different mass values as well
Asked by elemecro on 2019-11-11 09:14:54 UTC
It looks like the inertial moment are not well defined. I recommend to define only the diagonal moments of inertia (Ixx, Iyy, Izz), you can use the information form https://en.wikipedia.org/wiki/List_of_moments_of_inertia (that also suggest the gazebo tutorial). If the problem continues I suggest sending some pictures with the inertia that gazebo GUI show from your model.
Asked by Saimon on 2019-11-15 15:52:09 UTC
