setting `<minDepth>` in gazebo tags does not propagate to robot description
When I set the minDepth parameter in the URDF file for my robot's wheels
<gazebo reference="wheel_rear_right_link">
       <minDepth>0.002</minDepth>
inside the Gazebo simulation I found that the min_depth parameter is set to 0 regardless. When I convert the xacro to sdf, those tags are not present in the code. Other gazebo elements for links from this tutorial also does not work.
But setting the sensor on the link inside the same gazebo reference tags does load the sensor. What does that imply?
Asked by kumpakri on 2019-11-14 03:53:06 UTC
From what I have found I usually try to follow the SDFormat Specifications tags over those found in the tutorial. Something like this has worked for me:
    <collision>
      <surface>
        <contact>
          <ode>
            <min_depth>0.01</min_depth>
          </ode>
        </contact>
      </surface>
This took a little digging through gazebo and sdf, but this is the gazebo code that loads the min_depth parameter as a surface parameter in gazebo. This sdf code is where the tag <minDepth> is parsed. I have not gotten the <minDepth> tag to work either, but I do know some of those tags listed in the tutorial do work, such as <provideFeedback>, so it is possibly a bug or I just don't know how to properly use <minDepth>.
Asked by rittersb on 2020-03-03 15:12:47 UTC
For me it does not work either way.
Asked by kumpakri on 2020-07-14 02:56:05 UTC
