Unstable real time speed
Hi all,
I'm not sure if this is a problem of gazebo or not. I have a simulation running with ROS Kinetic and Gazebo 9. A similar problem happens with Gaebo 7
On a "good day" the simulation can run at 0.8 real time, on a "bad day" simulation won't run over 0.4 and some other days the speed would slow down within the day.
I have been thinking that it could be some problem related to power management/cpu temperature? Does anyone has experienced similar problems?
PS1: Given that the IMU sensor seems to give inconsistent results when speed changes so drastically, I'm running the simulation at 0.5, but some days the simulation can't keep up with that speed.
PS2: I'm working on a laptop, which is constantly connected to power.
Asked by gecastro on 2019-12-16 22:02:29 UTC
A lot of factors add to the real time factor you see on Gazebo. Foe example:
  • How complex is your model and whether inertial tensor you have used match with the collision you are using in xacro/urdf file
    • How many models you have spawned in Gazebo
    • How many nodes you are running
    • What is the publish rate of those nodes
    • Are you using sensors like laser, camera, GPS, etc. A good remedy can be to run the simulation at the slower than real time. Also try to simplify your model.
Asked by rahul on 2019-12-17 22:19:14 UTC
It is 1 model, a Robotis ThorMang, approximately 23 nodes, including gazebo. I'm already running the simulation below real-time speed, my question goes more on the inconsistency. It usually ends up "stabilizing" anywhere between 0.3 to 0.8. It runs perfectly well at 0.8, some times... Note, if I unplug the power cord from the laptop, the power-saving features of the processor kick in and the simulation runs at 0.25 I started capping the speed to 0.5. Now, I'm down to 0.25. It seems ok so far
Asked by gecastro on 2020-01-02 22:50:08 UTC
