Velodyne VLP-16 is showing only 1 beam instead of 16 beams in Gazebo
I am trying to build a Velodyne VLP-16 but using the official documentation of the velodyne hdl-32 as I would like to replicate the physical simulation in Gazebo. As you can see in the image below I am only getting 1 beam instead of 16 beams.
error
What I was expecting was something similar to the image below with all the 16 beams:
vlp16
Below the xml file I have been working on, but now I stopped because of that:
<?xml version="1.0" ?>
<sdf version="1.5">
    <world name="location_monitor">
        <uri>model://sun</uri>
    <!-- A ground plane -->
        <model name="velodyne_vlp_16">
            <!-- This is the BASE of the Lidar -->
            <link name="base">
            <!-- Offset the base by half the lenght of the cylinder -->
            <pose>0 0 0.0084 0 0 0</pose>
              <mass>0.10</mass>
                <ixx>0.000064852</ixx>
                <iyy>0.000064852</iyy>
                <izz>0.000125</izz>
            <collision name="base_collision">
                    <cylinder>
                    <!-- Radius and length provided by Velodyne -->
                    <radius>0.05</radius>
                    <length>0.0168</length>
                    </cylinder>
            <!-- The visual is mostly a copy of the collision -->
            <visual name="base_visual">
                    <cylinder>
                    </cylinder>
            <!-- This is the TOP of the Lidar -->
            <link name="top">
            <!-- Vertically offset the top cylinder by the length of the bottom
                cylinder and half the length of this cylinder. -->
                <pose>0 0 0.0637 0 0 0</pose>
                  <mass>0.10</mass>
                    <izz>0.000125</izz>
                <collision name="top_collision">
                        <cylinder>
                        </cylinder>
            <visual name="top_visual">
                <cylinder>
                </cylinder>
          <!-- LASER SCAN -->
          <link name="laser_scan">
            <sensor type="ray" name="sensor">
            <!-- Position the ray sensor based on the specification. also rotate
            it by 90 degree around the X-axis so that the horizontal rays become vertical-->
            <pose>0 0 -0.004645 1.5707 0 0</pose>
            <!-- Enable visualization to see the rays in the GUI -->
            <!-- Set the update rate of the sensor -->
                <ray>
                    <!-- The scan element contains the horizontal and vertical beams.
                    We are leaving out the vertical beams for now -->
                    <scan>
                    <!-- The horizontal beams -->
                        <horizontal>
                            <!-- The velodyne puck has 16 beams(samples)-->
                            <samples>16</samples>
                            <!-- Resolution is multiplied by samples to determine number of
                            simulated beams vs interpolated beams -->
                            <resolution>1</resolution>
                            <!-- Min angle in radians -->
                            <min_angle></min_angle>
                            <!-- Max angle in radians -->
                            <max_angle></max_angle>
                        </horizontal>
                    </scan>
                    <!-- Range definee characteristics of an individual beam -->
                    <range>
                        <!-- Minimum distance of the beam -->
                        <min>0.05</min>
                        <!-- Maximum distance of the beam -->
                        <max>100</max>
                        <!-- Linear resolution of the beam -->
                        <resolution>0.02</resolution>
                    </range>
                </ray>
          <!-- Diminuisco la z e lo scan si abbassa -->
          <pose>0 0 0.036 0 0 0</pose>
              <mass>0.63</mass>
                <ixx>0.000469959</ixx>
                <iyy>0.000469959</iyy>
                <izz>0.0007875</izz>
            <collision name="laser_collision">
                  <cylinder>
                  <length>0.0381</length>
                  </cylinder>
            <visual name="laser_visual">
                <cylinder>
                </cylinder>
          <!-- Each joint must have a unique name -->
          <joint type="revolute" name="base_joint">
            <!-- Position the joint at the bottom of the top link -->
            <pose>0 0 0.0004 0 0 0</pose>
            <!-- Use the base link as the parent of the joint -->
            <parent>base</parent>
            <!-- Use the top link as the child of the joint -->
            <child>laser_scan</child>
            <!-- The axis defines the joint's degree of freedom -->
            <axis>
              <!-- Revolve around the z-axis -->
              <xyz>0 0 1</xyz>
              <!-- Limit refers to the range of motion of the joint -->
              <limit>
                <!-- Use a very large number to indicate a continuous revolution -->
                <lower>-10000000000000000</lower>
                <upper>10000000000000000</upper>
              </limit>
            </axis>
          <joint type="revolute" name="top_joint">
            <pose>0 0 -0.0004 0 0 0</pose>
          <!--            0 0 0.0084 0 0 0-->
            <parent>top</parent>
            <axis>
              <xyz>0 0 1</xyz>
              <limit>
              </limit>
            </axis>
    </world>
Thanks for shedding light on this problem.
Asked by RayGz on 2019-12-30 11:45:06 UTC
