Unable to launch gazebo Cannot mix incompatible Qt library
I got a problem when launch gazebo empty_world by using this command
roslaunch gazebo_ros empty_world.launch
Got an error
[gazebo_gui-3] process has died [pid 9940, exit code 134, cmd /opt/ros/melodic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/eko_rudiawan/.ros/log/8d0c817e-375c-11ea-9da8-94b86d292534/gazebo_gui-3.log].
log file: /home/eko_rudiawan/.ros/log/8d0c817e-375c-11ea-9da8-94b86d292534/gazebo_gui-3*.log
But running gazebo using start menu is normal. Try run from terminal with command
gazebo --verbose
Got an error message
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.102
[Err] [GuiIface.cc:124] Cannot mix incompatible Qt library (version 0x50905) with this library (version 0x50c05)
The problem looks like incompatible with QT library I usually run ROS with Conda environment, and check the version with qmake --version
QMake version 3.1
Using Qt version 5.9.7 in /home/eko_rudiawan/anaconda3/envs/ros_env/lib
Is there any solution to solve this problem?? I used ROS Melodic in Linux Mint 19.3 Tricia with Gazebo 9 installed
Asked by ekorudiawan on 2020-01-15 01:17:23 UTC
Interesting. Not sure what mechanism is using the loader to complain about Qt versions but seems like a mix of qt 5.9.5 and 5.12.5 (if I'm not wrong with hex). Which qt version do you have in Mint? Where does gazebo come from (Conda?, Mint?)?
Asked by Jose Luis Rivero on 2020-01-23 11:24:23 UTC
I checked with installed QT version with
dpkg -l | grep libqt
It is listed qt 5.9.5, I use Linux mint 19.3 and gazebo is installed with ROS
Asked by ekorudiawan on 2020-01-23 21:16:02 UTC
The version is conda https://anaconda.org/conda-forge/qt seems to be 5.12.5, which are the versions displayed by the error command. My hypothesis is that there is a conflict somehow between them, although I have no idea how can you solve it.
Asked by Jose Luis Rivero on 2020-01-27 12:37:06 UTC
