URDF -> SDF ignores effort and velocity limits for continuous joints
I've found that if I define a continuous joint in my URDF with velocity and effort limits (but not position limits because it is continuous), the converter to sdf creates a revolute joint with limits of +/- 1e16 (fine) but no effort or velocity limits (not fine). Is this a known bug?
I've been using the workaround of just declaring the joints as revolute with +/-1e16 limits in the URDF and that works but is a bit ugly.
I'm using gz from Gazebo 10.
Thanks.
Asked by Jenny B on 2020-01-15 16:29:06 UTC
Same problem here for gazebo 11, it seems all the limits are ignored for continuous joint type
Asked by itazura on 2020-08-20 05:33:24 UTC
