set joint positions while using position_controllers/JointTrajectoryController
I have created a plugin to set joint positions based on the C++ API joint->SetPosition(). Although when I use a ROS controller type position_controllers/JointTrajectoryController I am no longer able to set the joint positions.
In particular I have noticed that the tyhe joint positions desired are set just for an istant an then the robot teleport the the previous joint position. I have even tried to stop and unload the controller but without any effect
Asked by tartaglia on 2020-01-23 12:10:10 UTC
