How to add laser sensor to my robot model
I have created my robot model and I'm able to successfully load it in Gazebo and make it move. Now, I would like to add a 2D laser sensor (30meters, 270°) but I'm having problems since I cannot see it in RVIZ.
When I run gmapping, for example, I continue to get:
Scan Matching Failed, using odometry. Likelihood=0
lp:-57.2393 0.222367 0.775704
and I can't see the laser beam in RVIZ when I select the laser frame as static frame.
How can I correctly add a laser sensor to my model?
This is my code for the robot model paviolier.urdf.xacro in my catkin workspace catkinws/src/paviolinerdescription/robot/:
<?xml version="1.0"?>
<robot name="pavioliner_xl" xmlns:xacro="http://www.ros.org/wiki/xacro">
<!-- Import pavioliner XL wheels -->
<xacro:include filename="$(find pavioliner_description)/urdf/wheels/omni_wheel.urdf.xacro" />
<xacro:include filename="$(find pavioliner_description)/urdf/base/pavioliner_base.urdf.xacro" />
<!-- Laser -->
<xacro:include filename="$(find pavioliner_description)/plugins/laser/hokuyo.xacro"/>
<xacro:laser name="pavioliner/laser" parent="pavioliner_base_link" xyz="0.13 0 0.36" rpy="0 0 0" meshes="package://gazebo_plugins/test/multi_robot_scenario/meshes/laser"/>
<!-- Wheel parameters -->
<xacro:property name="front_wheel_offset_x" value="0.37" /> <!-- x,y,z in translation from base_link to the center of the wheel -->
<xacro:property name="front_wheel_offset_y" value="0.46" />
<xacro:property name="wheel_offset_z" value="0.0" />
<xacro:property name="back_wheel_offset_y" value="0.46" />
<xacro:property name="back_wheel_offset_x" value="0.45" />
<xacro:macro name="robot">
<xacro:pavioliner_base/>
<xacro:omni_wheel prefix="pavioliner_front_right" parent="pavioliner_base_link" reflect="false">
<origin xyz="${front_wheel_offset_x} -${front_wheel_offset_y} ${wheel_offset_z}" rpy="0 0 0"/>
</xacro:omni_wheel>
<xacro:omni_wheel prefix="pavioliner_front_left" parent="pavioliner_base_link" reflect="true">
<origin xyz="${front_wheel_offset_x} ${front_wheel_offset_y} ${wheel_offset_z}" rpy="0 0 0"/>
</xacro:omni_wheel>
<xacro:omni_wheel prefix="pavioliner_back_left" parent="pavioliner_base_link" reflect="true">
<origin xyz="-${back_wheel_offset_x} ${back_wheel_offset_y} ${wheel_offset_z}" rpy="0 0 0"/>
</xacro:omni_wheel>
<xacro:omni_wheel prefix="pavioliner_back_right" parent="pavioliner_base_link" reflect="false">
<origin xyz="-${back_wheel_offset_x} -${back_wheel_offset_y} ${wheel_offset_z}" rpy="0 0 0"/>
</xacro:omni_wheel>
<xacro:omni_steering/>
</xacro:macro>
<xacro:robot/>
</robot>
and this is the hokuyo.xacro file in catkinws/src/paviolinerdescription/plugins/:
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
<!-- Front Laser -->
<xacro:macro name="laser" params="name parent xyz rpy meshes" >
<joint name="${parent}_${name}_joint" type="fixed">
<axis xyz="0 0 1" />
<origin xyz="${xyz}" rpy="${rpy}"/>
<parent link="${parent}"/>
<child link="${name}"/>
<link name="${name}">
<collision>
<box size="0.1 0.1 0.1"/>
<visual>
<mesh filename="${meshes}/hokuyo.dae"/>
<mass value="1e-5" />
<inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6" />
<gazebo reference="${name}">
<sensor name="laser" type="ray">
<pose>0 0 0 0 0 0</pose>
<ray>
<scan>
<horizontal>
<!-- The URG-04LX-UG01 has 683 steps with 0.35139 Degree resolution -->
<resolution>1</resolution>
<max_angle>2.0944</max_angle> <!-- 120 Degree -->
<min_angle>-2.0944</min_angle> <!-- -120 Degree -->
<samples>683</samples>
</horizontal>
</scan>
<range>
<min>1</min>
<max>80</max>
<resolution>0.01</resolution>
</range>
</ray>
<plugin name="laser" filename="libgazebo_ros_laser.so" >
<robotNamespace></robotNamespace>
<topicName>laser/scan</topicName>
<frameName>laser</frameName>
<plugin name="laser" filename="libRayPlugin.so" />
</xacro:macro>
</robot>
Asked by marcusbarnet on 2020-01-26 12:27:29 UTC
