Cannot spawn Solidworks generated urdf model to gazebo.
Dear SIrs, I have tried all I know to spawn a model created using Solidworks to Gazebo for simulation. The urdf file has been exported using a tool for creating urdf files inside Soliworks.
The urdf file is the following:
This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
Commit Version: 1.5.1-0-g916b5db Build Version: 1.5.7152.31018
For more information, please see http://wiki.ros.org/sw_urdf_exporter
<robot name="robot_urdf">
<link name="robot_base">
<origin xyz="0.152 -0.0625420962769482 0.00703464237079188" rpy="0 0 0"/>
<mass value="0.328439502632123"/>
<inertia ixx="0.00166317188204101" ixy="5.84339679477964E-19" ixz="1.91934869525446E-20" iyy="0.00265002456943154" iyz="0.000616470492128439" izz="0.00376104038840237"/>
<visual>
<mesh filename="package://robot_urdf/meshes/robot_base.STL"/>
<material name="">
<color rgba="1 1 1 1"/>
<collision>
<joint name="j4" type="continuous">
<origin xyz="0.15591 -0.075981 -0.0035605" rpy="0.41868 0 3.1416"/>
<parent link="robot_base"/>
<child link="w4"/>
<axis xyz="1 0 0"/>
<link name="w1">
<origin xyz="0.014 0 -3.4694E-18" rpy="0 0 0"/>
<mass value="0.061522"/>
<inertia ixx="5.5443E-05" ixy="8.9343E-21" ixz="-4.0706E-22" iyy="3.0092E-05" iyz="-5.0822E-21" izz="3.0092E-05"/>
<visual>
<mesh filename="package://robot_urdf/meshes/w1.STL"/>
<material name="">
<color rgba="0.29804 0.29804 0.29804 1"/>
<collision>
<joint name="j1" type="revolute">
<origin xyz="0.304 -0.109634968085994 0.0487870246354819" rpy="2.14240707483869 0 0"/>
<child link="w1"/>
<axis xyz="1 0 0"/>
<limit lower="0" upper="0" effort="0" velocity="0"/>
<link name="w2">
<origin xyz="-0.014 1.0408E-17 0" rpy="0 0 0"/>
<inertia ixx="5.5443E-05" ixy="-1.8201E-20" ixz="6.2244E-21" iyy="3.0092E-05" iyz="-5.9292E-21" izz="3.0092E-05"/>
<visual>
<mesh filename="package://robot_urdf/meshes/w2.STL"/>
<material name="">
<collision>
<joint name="j2" type="revolute">
<origin xyz="-3.58147028304556E-05 -0.109634968085994 0.0487870246354823" rpy="-2.3203312160931 0 0"/>
<child link="w2"/>
<axis xyz="1 0 0"/>
<link name="w3">
<origin xyz="0.014 -3.4694E-18 -1.3878E-17" rpy="0 0 0"/>
<inertia ixx="5.5443E-05" ixy="6.5784E-21" ixz="-2.0743E-21" iyy="3.0092E-05" iyz="-1.1011E-20" izz="3.0092E-05"/>
<visual>
<mesh filename="package://robot_urdf/meshes/w3.STL"/>
<material name="">
<collision>
<joint name="j3" type="revolute">
<origin xyz="0.304 0 0" rpy="1.48802974926342 0 0"/>
<child link="w3"/>
<axis xyz="1 0 0"/>
<link name="w4">
<origin xyz="-0.014 0 0" rpy="0 0 0"/>
<mass value="0.0615219544751675"/>
<inertia ixx="5.54433425808419E-05" ixy="9.27882825319427E-21" ixz="7.86127790599438E-22" iyy="3.00921775305435E-05" iyz="-1.6940658945086E-21" izz="3.00921775305435E-05"/>
<visual>
<mesh filename="package://robot_urdf/meshes/w4.STL"/>
<material name="">
<color rgba="0.298039215686275 0.298039215686275 0.298039215686275 1"/>
<collision>
<joint name="j4" type="revolute">
<child link="w4"/>
<axis xyz="1 0 0"/>
</robot>
The launch file is the following:
<launch>
<include
file="$(find gazebo_ros)/launch/empty_world.launch" />
<node
name="tf_footprint_base"
pkg="tf"
type="static_transform_publisher"
args="0 0 0 0 0 0 base_link base_footprint 40" />
<node
name="spawn_model"
pkg="gazebo_ros"
type="spawn_model"
args="-file $(find robot_urdf)/urdf/robot_urdf.urdf -urdf -model robot_urdf"
output="screen" />
<node
name="fake_joint_calibration"
pkg="rostopic"
type="rostopic"
args="pub /calibrated std_msgs/Bool true" />
</launch>
There are some mesh files included is a mesh directory in .STL format
The error message I get when running the launch command is the following:
Error [parser_urdf.cc:3408] Unable to call parseURDF on robot model Error [parser.cc:340] parse as old deprecated model file failed.
Any directions appreciated...
Asked by Michael1973 on 2020-01-26 13:56:35 UTC
