How to enable bounce with DART engine?
Hi all,
I want to simulate bounce with the DART engine. I set restitution_coefficient and threshold under the bounce tag, however, it does not work.
This answer says that max_vel value under the ode tag must be also set. However, max_vel is valid only when ODE is set as the physics engine.
In addition, when max_vel is set, restitution_coefficient and threshold are ignored, then kp and kd under the ode tag are referred (This answer's last comment mentions it).
Is there any way to set a restitution coefficient with DART engine?
Here is my world.sdf and I run it Gazebo 9 on Ubuntu18.04.
Thank you.
<?xml version="1.0" ?>
<sdf version="1.6">
  <world name="world">
    <gravity>0 0 -9.80665</gravity>
    <physics default="true" type="dart">
      <dart>
        <solver>
          <solver_type>dantzig</solver_type>
        </solver>
      </dart>
    </physics>
    <!-- <physics type="ode">
    </physics> -->
      <uri>model://sun</uri>
    <!-- Ground -->
    <!-- Ball -->
    <model name="Ball">
      <static>false</static>
      <pose>0 0 2 0 0 0</pose>
      <link name="Ball">
        <pose>0 0 0 0 0 0</pose>
          <mass>8</mass>
            <ixx>3.2</ixx>
            <ixy>0.0</ixy>
            <ixz>0.0</ixz>
            <iyy>3.2</iyy>
            <iyz>0.0</iyz>
            <izz>3.2</izz>
        <visual name="vis_Ball">
            <sphere>
              <radius>1</radius>
            </sphere>
        <collision name="coll_Ball">
          <pose>0 0 0</pose>
            <sphere>
              <radius>1</radius>
            </sphere>
          <surface>
            <bounce>
              <restitution_coefficient>1</restitution_coefficient>
              <threshold>0</threshold>
            </bounce>
            <!-- <contact>
              <ode>
                <kp>1e+12</kp>
                <kd>1</kd>
                <max_vel>1000</max_vel>
              </ode>
            </contact> -->
            <friction>
              <ode>
                <mu>0</mu>
                <mu2>0</mu2>
              </ode>
            </friction>
          </surface>
  </world>
Asked by hued on 2020-01-29 01:56:43 UTC
hi, I find the same bounce issue in Bullet physics engine. did you solve the problem? Thank you
Asked by tom8o on 2022-09-09 14:10:20 UTC
