Cannot install gazebo from source ("sdf9format missing) Ubuntu 18.04
Im installing and following every step in this page http://gazebosim.org/tutorials?tut=install_from_source&cat=install
But when I get to building and installing it, when i configure gazebo in release mode with cmake ../ I get this output error:
Asked by zhevas on 2020-01-29 02:52:25 UTC
It looks like you're trying to compile the most recent branch, with a version that hasn't been released yet. For Gazebo 9 for example, try doing this first in your clone directory:
hg up gazebo9
The tutorial has a note about this, "Note: the default branch is the development branch where you'll find the bleeding edge code, your cloned repository should be on this branch by default but we recommend you switch to the gazebo6 branch if you desire more stability," but maybe we could be a bit more explicit with instructions.
Asked by chapulina on 2020-01-29 22:13:59 UTC
