fatal error: gazebo/gazebo.hh: No such file or directory
Hey, I want to add a gps sensor on my robot. Initially i tried adding the gps sensor in the urdf.xacro file, but no much luck there. So I thought to create a .cpp file as i found by hector_plugins. But when im trying to compile the c++ file i get the following error
 #include <gazebo/gazebo.hh>
compilation terminated.
When I'm doing the plugin_tutorials everything works perfectly, but when I try to compile it with my files i get the above error. My aim is to extract data about the x,y,z position of my rover.
My cpp code:
#include <functional>
#include <ignition/math/Vector3.hh>
namespace gazebo
    class ModelPush : public ModelPlugin
            //Store pointer to model
            this->model = _parent;
            //Listen to update event. This event is broadcast every simulation iteration
                    std::bind(&ModelPush::OnUpdate, this));
        //Called by the world update start event
        public: void OnUpdate()
            //Get x,y,z position
            this->model->GetWorldPose();
        //Pointer to the model
        //Pointer to the update event connection
        //Register plugin with simulation
        GZ_REGISTER_MODEL_PLUGIN(ModelPush)
And to compile it i added these two lines in the CMakeLists.txt
addexecutable(xyzpush src/xyzpush.cpp)
targetlinklibraries(xyzpush ${catkin_LIBRARIES})
Any help will be appreciated. Thanks in advance!
Asked by Kyriakos on 2020-01-31 12:07:38 UTC
First, be sure that you have install the libgazeboX-dev (where X is the version of gazebo being used) package if your are using Debian/Ubuntu system.
Second, give a look again into the tutorial and remember to include the include_directories(${GAZEBO_INCLUDE_DIRS}) in our CMakeLists.txt file.
Asked by Jose Luis Rivero on 2020-02-04 10:55:31 UTC
Thanks for your answer but this is not the problem, i have everything installed and when i insert the include_directories(${GAZEBO_INCLUDE_DIRS}) the code still doesn't compile When i do the tutorial it works perfectly without any errors regarding #include gazebo/gazebo.hh but when i try to compile the code above i get that error.
Asked by Kyriakos on 2020-02-04 14:05:47 UTC
cmake cache could be tricking you, remove the CMakeCache.txt file from the build directory and try again. If that does not fix the situation I would recommended to start using the tutorial example and change the tutorial files by yours progressively. Good luck.
Asked by Jose Luis Rivero on 2020-02-04 14:11:35 UTC
