Gazebo - IIWA 14 effort_controllers/JointPositionController or JointVelocityController or JointEffortController and J2 ( second joint) doesn't have enough force to move it
The solution is increase the value of the safetycontrollerk_vel parameter in the file "iiwa14.xacro", which is the model that i am using, and it started to work properly. I haven't got time to see what to do this parameter so it isn't good adjust. I wrote 2.8 (line 14 in my iiwa14.xacro file)instead of 2, that was the default value.
If could anyone help to know how to configure safetycontrollerk_vel parameter i will really aprecciate it.
You should use "yourmodelrobotxacrofile.xacro".
ATTENTION: The next file is .xacro not .cpp but gazebo forum didn't let me upload in .xacro format.
Next, I explain in detail my failure.
I'm using in gazebo the iiwa 14 robot from Salvatore Virga stack: https://github.com/IFL-CAMP/iiwa_stack.
I want to command the robot by effort and to measure the efforts from each joint so i change the default Hardware Interface " PositionJointInterface " for " EffortJointInterface "
C:\fakepath\iiwa_gazebo.launch
The problem is that the joint 2 hasn't got force enough to move the robot and it went down to the floor. Firstly i believed that it was a pid problem by a bad setting of proportional, derivative and integral values. After i tested high and small pid values the failure continue so i was looking for in the differents files about limitation in the effort.
But i discovered that the limitation wasn't in the effort if not in the velocity ( safetycontrollerk_vel) because i used higher values for:
max_effort
max_velocity
joint_damping
And the robot continued without it can't move its joint 2. But increasing the safetycontrollerk_vel, it is fix.
Asked by Nacho12 on 2020-02-01 05:09:50 UTC
