Remove Collisions from object
I am currently working on a project where a vehicle has to go to a set number of way points. I wanted to add a visual feature so that users could see where the current way point is in gazebo.
My solution to this was to spawn a cylinder with small length and changes its position whenever the vehicle begins to head to a new waypoint. The problem I am facing is that whenever the vehicle touches the cylinder it moves. I have looked online and learned that i can use the collidewithoutcontact tag to eliminate this, however, when I do this my object disappears.
Would anyone know how to eliminate the collisions on a particular object?
<?xml version="1.0"?>
<sdf version="1.6">
<model name="marker">
<static>false</static>
<link name="marker">
<collision name='collision'>
<cylinder>
<radius>1</radius>
<length>0.001</length>
</cylinder>
<surface>
<contact>
<collide_without_contact>true</collide_without_contact>
</contact>
</surface>
<visual name="marker">
<pose>0 0 0.001 0 0 0</pose>
<cylinder>
<radius>1</radius>
</cylinder>
<script>
<name>Gazebo/Green</name>
</script>
Asked by H on 2020-02-01 16:03:49 UTC
Just remove the "collision" part:
<sdf version="1.6">
<cylinder>
<radius>1</radius>
</cylinder>
<script>
</script>
Asked by Mansan on 2020-02-19 06:38:37 UTC
