ROS/Gazebo Camera Plugin Crashing
Hi all - I am having some problems with the ROS/Gazebo Camera Plugin. I started out with following the link here: http://gazebosim.org/tutorials?tut=ros_gzplugins and putting the sensor/plugin together in my sdf file and everything was working fine, including publishing the image topic via ROS. Now it seems that the plugin doesn't work, and as far as I can tell nothing changed on my system.
Here is a link to the sdf file in question: https://github.com/dgitz/icarus_config/blob/master/scenarios/scout_sim/models/110010-RaspiCam1/model.sdf
When I click the "Start" buttin in Gazebo I get the following error: Segmentation fault (core dumped) [gazebo-1] process has died [pid 31712, exit code 139, cmd /opt/ros/kinetic/lib/gazeboros/gzserver -u -e ode /home/robot/catkinws/src/icarussim/worlds/hardworld.world _name:=gazebo __log:=/home/robot/.ros/log/483a4954-3479-11ea-ace1-b827ebcf9c85/gazebo-1.log]. log file: /home/robot/.ros/log/483a4954-3479-11ea-ace1-b827ebcf9c85/gazebo-1*.log
If I comment out the plugin section in the sdf file my Gazebo model will run fine, just won't publish the image via ROS. I am using Gazebo v9, and for troubleshooting I verified the GAZEBOPLUGINPATH contains this plugin and also did a sudo apt-get update and upgrade.
Anybody have any ideas?
Asked by davidgitz on 2020-02-01 21:49:09 UTC
