model plugin make error
Hi i'm using gazebo 9, ubuntu 18.04 and ros-melodic.
I have a custom quadruped robot model, and a custom model plug-in that I made for use here. Actually these are working fine in other computers, but not mine.
When I try to catkin_make, an error occured described below.
[ 98%] Building CXX object aidinvi/CMakeFiles/sub_aidinvi.dir/src/sub_aidinvi.cpp.o In file included from /usr/include/gazebo-9/gazebo/common/common.hh:36:0,
from /usr/include/gazebo-9/gazebo/gazebo_core.hh:19,
from /usr/include/gazebo-9/gazebo/gazebo.hh:20,
from /home/onesoulkang/catkin_ws/src/aidinvi/src/sub_aidinvi.cpp:2: /usr/include/gazebo-9/gazebo/common/Plugin.hh:420:10: error: expected unqualified-id before string constant
extern "C" GZ_PLUGIN_VISIBLE gazebo::ModelPlugin *RegisterPlugin(); \
/usr/include/gazebo-9/gazebo/common/Plugin.hh:420:10: note: in definition of macro GZ_REGISTER_MODEL_PLUGIN’
aidinvi/CMakeFiles/sub_aidinvi.dir/build.make:62: recipe for target 'aidinvi/CMakeFiles/sub_aidinvi.dir/src/sub_aidinvi.cpp.o' failed
make[2]: *** [aidinvi/CMakeFiles/sub_aidinvi.dir/src/sub_aidinvi.cpp.o] Error 1 CMakeFiles/Makefile2:3604: recipe for target 'aidinvi/CMakeFiles/sub_aidinvi.dir/all' failed
make[1]: *** [aidinvi/CMakeFiles/sub_aidinvi.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2 Invoking "make -j4 -l4" failed
Does anyone have any suggestions for handling this problem?
Asked by kanghs0822 on 2020-02-04 11:00:29 UTC
While I don't have your code to see, this is most likely due to forgetting to put a semi-colon at the end of your class definition.
You defined your class like this:
namespace gazebo
class SimplePlugin: public ModelPlugin
Instead of:
namespace gazebo
Asked by zokowc on 2020-03-20 14:47:58 UTC
Go to catkin_ws, delete the build folder and rebuild the workspace using catkin_make.
Asked by malikibnueasa on 2023-02-28 10:46:01 UTC
