No rule to make target libOgreMain.so when building ign-rendering under Debian 10
I'm attempting to get Ignition Citadel built under Debian 10 and feel I'm pretty close. I'm getting the following make error while building ign-rendering:
make[2]: *** No rule to make target '/usr/lib/x86_64-linux-gnu/libOgreMain.so', needed by 'lib/libignition-rendering3-ogre.so.3.0.0'. Stop.
make[1]: *** [CMakeFiles/Makefile2:2642: ogre/src/CMakeFiles/ignition-rendering3-ogre.dir/all] Error 2
make: *** [Makefile:163: all] Error 2
My CMake output for ign-rendering is:
ignition/build/ignition-rendering3$ cmake ../../src/ign-rendering/
-- ignition-rendering3 version 3.0.0
-- Operating system is Linux
-- Found CPack generators: DEB
-- Looking for ignition-math6 -- found version 6.4.0
-- Searching for dependencies of ignition-math6
-- Looking for ignition-math6 - found
-- Looking for ignition-common3 -- found version 3.3.0
-- Searching for dependencies of ignition-common3
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- Checking for module 'uuid'
-- Found uuid, version 2.33.1
-- Searching for <ignition-common3> component [graphics]
-- Looking for ignition-common3-graphics -- found version 3.3.0
-- Searching for dependencies of ignition-common3-graphics
-- Searching for <ignition-common3> component [events]
-- Looking for ignition-common3-events -- found version 3.3.0
-- Searching for dependencies of ignition-common3-events
-- Looking for ignition-common3 - found
-- Looking for ignition-plugin1 -- found version 1.1.0
-- Searching for dependencies of ignition-plugin1
-- Searching for <ignition-plugin1> component [all]
-- Looking for all libraries of ignition-plugin1 -- found version 1.1.0
-- Looking for ignition-plugin1-loader -- found version 1.1.0
-- Searching for dependencies of ignition-plugin1-loader
-- Looking for ignition-plugin1-register -- found version 1.1.0
-- Searching for dependencies of ignition-plugin1-register
-- Looking for ignition-plugin1 - found
-- Looking for FreeImage - found
CMake Warning (dev) at /usr/share/cmake-3.13/Modules/FindOpenGL.cmake:270 (message):
Policy CMP0072 is not set: FindOpenGL prefers GLVND by default when
available. Run "cmake --help-policy CMP0072" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
FindOpenGL found both a legacy GL library:
OPENGL_gl_LIBRARY: /usr/lib/x86_64-linux-gnu/libGL.so
and GLVND libraries for OpenGL and GLX:
OPENGL_opengl_LIBRARY: /usr/lib/x86_64-linux-gnu/libOpenGL.so
OPENGL_glx_LIBRARY: /usr/lib/x86_64-linux-gnu/libGLX.so
OpenGL_GL_PREFERENCE has not been set to "GLVND" or "LEGACY", so for
compatibility with CMake 3.10 and below the legacy GL library will be used.
Call Stack (most recent call first):
/home/code/ignition/install/ignition-cmake2/share/cmake/ignition-cmake2/cmake2/IgnUtils.cmake:188 (find_package)
CMakeLists.txt:52 (ign_find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Looking for OpenGL - found
-- Checking for module 'OGRE-RTShaderSystem >= 1.8'
-- Found OGRE-RTShaderSystem , version 1.9.0
-- Checking for module 'OGRE-Terrain >= 1.8'
-- Found OGRE-Terrain , version 1.9.0
-- Checking for module 'OGRE-Overlay >= 1.8'
-- Found OGRE-Overlay , version 1.9.0
-- Looking for IgnOGRE - found
-- Boost version: 1.67.0
-- Looking for IgnOGRE2 - found
CUDA_TOOLKIT_ROOT_DIR not found or specified
-- Could NOT find CUDA (missing: CUDA_TOOLKIT_ROOT_DIR CUDA_NVCC_EXECUTABLE CUDA_INCLUDE_DIRS CUDA_CUDART_LIBRARY)
-- optix library not found. Please locate before proceeding.
-- OptiX headers (optix.h and friends) not found. Please locate before proceeding.
-- optix Prime library not found. Please locate before proceeding.
-- Could NOT find OptiX (missing: OptiX_FOUND) (Required is at least version "3.8.0")
-- Looking for OptiX - not found
-- BUILD WARNINGS
-- Cannot build component [optix] - Missing: OptiX
-- END BUILD WARNINGS
-- Searching for host SSE information
-- SSE2 found
-- SSE3 found
-- SSE4.1 found
-- SSE4.2 found
-- Configuring library: ignition-rendering3
-- Adding 23 UNIT tests
-- Adding 7 INTEGRATION tests
-- Adding 1 PERFORMANCE tests
-- No tests have been specified for REGRESSION
-- Configuring library: ignition-rendering3-ogre
CMake Warning (dev) at /home/code/ignition/install/ignition-cmake2/share/cmake/ignition-cmake2/cmake2/IgnUtils.cmake:1241 (target_link_libraries):
Policy CMP0079 is not set: target_link_libraries allows use with targets in
other directories. Run "cmake --help-policy CMP0079" for policy details.
Use the cmake_policy command to set the policy and suppress this warning.
Target
ignition-rendering3-all
is not created in this directory. For compatibility with older versions of
CMake, link library
will be looked up in the directory in which the target was created rather
than in this calling directory.
ogre/src/CMakeLists.txt:5 (ign_add_component)
-- No tests have been specified for UNIT
-- Configuring library: ignition-rendering3-ogre2
Target
CMake, link library
ogre2/src/CMakeLists.txt:5 (ign_add_component)
-- The program [cppcheck] was not found! Skipping codecheck setup
-- Build configuration successful
-- Build type: RelWithDebInfo
-- Install prefix: /home/code/ignition/install/ignition-rendering3
-- Configuring done
-- Generating done
-- Build files have been written to: /home/code/ignition/build/ignition-rendering3
I followed the Ubuntu Bionic Source Install steps (https://ignitionrobotics.org/docs/citadel/install_ubuntu_src) for the most part. Key differences are building some deps from source that are not available as packages in Debian 10 stable or back-ports. I built dart v6.9.2 from source and the OSRF fork of Ogre 2.1 from here (https://github.com/osrf/ogre-2.1-release). With respect to Ogre 2.1, I used commit hash e406949420fa1b2195f0f3d9f7c9546c8a78ff40 as the latest commit seems to have broken things. I generated deb packages by running fakeroot debian/rules
from the ogre-2.1-release
folder and then installed them with sudo dpkg -i *.deb
. ign-rendering CMake seems to be happy with the dual 1.9, 2.1 install.
In terms of libOgreMain.so
installed on my system, you can see it here:
ls -la /usr/lib/x86_64-linux-gnu/ | grep libOgre
-rw-r--r-- 1 root root 108872 Nov 17 2018 libOgreHlmsPbsMobile.so.2.1.0
-rw-r--r-- 1 root root 403904 Nov 17 2018 libOgreHlmsPbs.so.2.1.0
-rw-r--r-- 1 root root 84448 Nov 17 2018 libOgreHlmsUnlitMobile.so.2.1.0
-rw-r--r-- 1 root root 157704 Nov 17 2018 libOgreHlmsUnlit.so.2.1.0
lrwxrwxrwx 1 root root 20 Nov 17 2018 libOgreMain.so -> libOgreMain.so.1.9.0
-rw-r--r-- 1 root root 6489352 Nov 17 2018 libOgreMain.so.2.1.0
-rw-r--r-- 1 root root 305160 Nov 17 2018 libOgreMeshLodGenerator.so.2.1.0
lrwxrwxrwx 1 root root 23 Nov 17 2018 libOgreOverlay.so -> libOgreOverlay.so.1.9.0
-rw-r--r-- 1 root root 993576 Nov 17 2018 libOgreOverlay.so.2.1.0
lrwxrwxrwx 1 root root 22 Nov 17 2018 libOgrePaging.so -> libOgrePaging.so.1.9.0
lrwxrwxrwx 1 root root 24 Nov 17 2018 libOgreProperty.so -> libOgreProperty.so.1.9.0
lrwxrwxrwx 1 root root 30 Nov 17 2018 libOgreRTShaderSystem.so -> libOgreRTShaderSystem.so.1.9.0
lrwxrwxrwx 1 root root 23 Nov 17 2018 libOgreTerrain.so -> libOgreTerrain.so.1.9.0
lrwxrwxrwx 1 root root 22 Nov 17 2018 libOgreVolume.so -> libOgreVolume.so.1.9.0
I understand that Debian 10 is not strictly supported, any help would be greatly appreciated.
Asked by adamwtow on 2020-02-07 22:34:58 UTC
Seems like it can not locate /usr/lib/x86_64-linux-gnu/libOgreMain.so. Is it in your filesystem? Should be part of libogre-1.9-dev package https://packages.debian.org/buster/amd64/libogre-1.9-dev/filelist.
Asked by Jose Luis Rivero on 2020-02-08 14:58:02 UTC
Ahh thank you. I incorrectly presumed my output of ls -la above meant that
was on my system. It wasn't. All sorted now. Thanks again.Asked by adamwtow on 2020-02-11 00:31:18 UTC
