model contact with ground issue
asked 2020-02-15 14:00:07 -0500
TorontoRoboticsClub gravatar image
updated 2020-02-15 14:20:33 -0500
I am running Gazebo7 ver 7.16 in Ubuntu 16.04 and Ros Kinetic.
I have a four wheeled robot that I am trying to simulate in Gazebo:
image description
The two front castor wheels are behaving "strange". I believe there are two issues and they are related:
Issue #1 - Dancing / moving / rotating I took pictures of the model in with no commands being given to it, and if you look at the two images below you will see the two front castor wheels are in slightly different positions (they have moved). The two wheels keep doing this motion where they turn inwards, and then outwards. this motion is done by both wheels and it takes about a second to do (inward to outward about a sec, and outward to inward about a sec). This motion never stops. I am hoping to eliminate this motion:
image description
image description
Here is a close up of the right wheel showing this motion (right wheel relative to robot):
image description
image description
Issue #2 - Contact with ground - I selected "contacts" from the "view" menu and the part of the wheel that makes contact with the ground changes many, many times a second. To show you what I mean I paused the simulation and took images as I pressed the "step" button on the bottom toolbar:
image description
image description
image description
image description
image description
image description
image description
Any suggestion on how my urdf has to change? what tags do I need to add to make the robot more stable?
My urdf is just shy of 800 lines, so I only included the items relevent to the right wheel (as the left wheel is identical).
reference image:
image description
URDF:
  <link name="right_castor_mount_link">
    <collision>
        <box size="0.1145 0.1 0.0057"/>
      <origin rpy="0 0 0" xyz="0 0 0"/>
    <visual>
      <material name="black"/>
      <mass value="0.25"/>
      <inertia ixx="0.000209010208333" ixy="0" ixz="0" iyy="0.000273807083333" iyz="0" izz="0.000273807083333"/>
  <joint name="base_to_right_castor_mount_joint" type="fixed">
    <parent link="base_link"/>
    <child link="right_castor_mount_link"/>
    <origin xyz="-0.09445 -0.344 -0.03265"/>
  <link name="right_castor_dummy_link">
    <collision>
        <box size="0.02 0.02 0.02"/>
    <visual>
      <material name="orange"/>
      <inertia ixx="1.66666666667e-05" ixy="0" ixz="0" iyy="1.66666666667e-05" iyz="0" izz="1.66666666667e-05"/>
  <joint name="right_castor_mount_to_right_castor_dummy_joint" type="continuous">
    <axis rpy="0 0 0" xyz="0 0 1"/>
    <parent link="right_castor_mount_link"/>
    <child link="right_castor_dummy_link"/>
    <origin xyz="0.0 0.0  -0.01"/>
    <dynamics damping="0.0" friction="1.0"/>
  <link name="right_castor_wheel_link">
    <collision>
        <cylinder length="0.049" radius="0.07925"/>
      <origin rpy="1.57079632679 0 0" xyz ...
(more)
answered 2020-02-15 18:00:48 -0500
updated 2020-02-15 20:52:41 -0500
The issue was the absense of kp and kd tags. Those tags are mentioned here: http://gazebosim.org/tutorials/?tut=r... and values that worked for me were found here: http://answers.gazebosim.org/question...
Here is what I needed to add:
  <gazebo reference="right_castor_wheel_link">
      <kp>1000000.0</kp> <!--contact stiffness-->
      <kd>100.0</kd> <!--damping-->
As soon as I put these values (for all 4 wheels), the castor wheels stopped moving, and the robot stopped shifting the weight side to side. However the robot is now slowly rolling backwards. any advice?
TorontoRoboticsClub gravatar imageTorontoRoboticsClub ( 2020-02-15 20:55:28 -0500 )edit
Asked: 2020-02-15 14:00:07 -0500
Seen: 1,884 times
Last updated: Feb 15 '20
